What happened to the HP (67->95)
Old Dec 9, 2003 | 11:07 AM
  #16
OldSStroker's Avatar
Originally posted by Van5150
Before Emissions at the Muscle Car peak those auto Engrs. did anything and everything they could to get more power. They had barely streetable cams, huge cubic inches, huge 4-barrels, some had 2-4 barrels.
Well, yes and no.
Some of the "huge" cams of the 60s were very lazy compared to today's profiles. So the had to use lots of duration and lots of overlap just to get some lift and area under the curve.
Most of the street engines, (not the very rare race engines) were not all that powerful. I worked for a major player at the time. We had 400 hp capacity dynos which could be overloaded to about 450 hp or so, and rarely did even a Super Duty engine max out the dyno.
For the typical Gross Horsepower test (GM 20, I think it was), the engine was run without an air cleaner or production exhaust system. The dyno exhaust was connected to the manifolds and had a slight vacuum to keep exhaust fumes out of the dyno room. No fan, no engine driven accessories and best fuel and spark timinlg. That means that at every step (no accelerating @ 300 rpm/second), the timing was adjusted by remotely rotating the distributor for best torque reading, then fuel mixture was adjusted for best torque then timing then fuel again until best of the best was reached. Then on to the next step.
How the was fuel was adjusted on the dyno was interesting: the float bowls were drilled and a small air fitting was installed. By putting a little pressure on top of the fuel in the bowl, the engine richened up a llittle. By pulling a slight vacuum on the top of the fuel in the bowl, it leaned up. Fuel flow at each point was recorded for BSFC and so the carb guys could try to duplicate that fuel curve fairly closely.
Even drag racers couldn't get that exact timing and fuel.
Oh yeah, power and torque were corrected to 60*F carb air inlet temp, dry air and 29.92 in Hg (I think). Rarely does an engine see those conditions in the real world.
There were also "as installed" tests run with all accessories exhaust, intake plumbing etc. run which pretty much duplicates today's method of rating production engines. Those numbers were never published before "net" numbers started being used.
Oh yeah, there was lots of lying. If an engine needed to have a hp rating of 348 hp @ 5200, maybe it did that in gross hp and maybe it didn't. To be fair, most of the production engines I saw were pretty much what was claimed in the gross hp test. Some were even underrated when the powers that be said stuff like a pony car couldn't have more hp than a Vette. In one case, a pony car needed to be about 15 hp below the signature muscle car with the exact same engine, so a little tab was added to the carb linkage to prevent full opening of the secondaries. Just bending that (fairly flimsy) tab out of the was was a quick 15 hp.
I can honestly say that I never saw any (non race) engine go over 400 hp in the "as installed" test which equates to today's readings. Not even close. With the LS6 already at 405, the factories are doing a heck of a lot better with 346 cubes on 91 octane than 450 cubes engines did on 100+ 35 or so years ago. Shoot, the Escalade 6.0 is stronger than any non-race engine I ever saw on the factory dyno.
Could you imagine the power we would have from the factory today if they had no emission rules to follow, if we had much higher octane gasoline. The technology today ie. Fuel Injection, Programable fuel/spark maps, even the camshafts we have today were not possible to make in the old days.
Absolutely! Airflow technology has come a very long way. Good head and cam and exhaust packages we put on LS1s today are an example of what you said. With a good possibility of nearly 500 rear wheel hp available with the correct airflow and valvetrain work, we are talking about 600 flywheel "gross" hp with bolt ons. That's about 50++ more than a NASCAR Grand National engine (today's Nextel Cup) actually dynoed back then.
But even if the factory could make these higher performing cars today, we would still find something to improve upon, thats what we do.
Yep, but it takes more than just a "Bobcat Package" of thin head gasket, advance curve and jet changes like it did back then.
Old Dec 9, 2003 | 12:01 PM
  #17
94formulabz's Avatar
That wouldn't have been the firebird competing with the gto would it?
Old Dec 9, 2003 | 06:23 PM
  #18
pelebkf's Avatar
Thank you for all your input it has been very helpful in answering the older generation and the false theorys of the new generation. But I what kind of gross hp is the lt1 putting out? and if it is lower hp than the older cars have what does a person like me do about that? (95z) It just seams like there is little to do to significantly raise the HP outside of a supercharger and NO2.
Old Dec 9, 2003 | 07:42 PM
  #19
dnz28's Avatar
the things that killed the hp yes the were rated different but back then a couple things basicly killed the muscle cars. first off leaded gas was no longer was thrown out hte window, made a little difference but not much then, the insurance companys got on to you the higher the hp rating from the factory the higher insurance, then they had a gas sortage which muscle cars were parked or sold for a more fuel friendly car. Also I think technology had a great deal to do with it way back they didnt think like they do now they though like a cave man. this is what they thought well we have a 4200 pound iron box with no aero dynamics beast that runs 14.0s in the quarter. so lets just add more power and bam they got better times. well now they think opposite it like lets take some weight off the car make it more aero dynamic and bam a car with half the hp but still goes just as fast if not way faster.
Old Dec 9, 2003 | 09:34 PM
  #20
firehawk0152's Avatar
When the LT1 engine came out in 1992, chevy stated that it had the highest net horsepower of any production small block.
300 gross horsepower=225 net horsepower
Big difference
Old Dec 10, 2003 | 07:48 AM
  #21
Strong possibility.
Old Dec 10, 2003 | 11:35 AM
  #22
aintno6's Avatar
Im gunna give the win to the old muscle cars. As stated before the tires that these cars came off the show room floor, would not provide no where near the needed traction to allow those cars to hook up.
If you were to go to a dragstrip back in 71 on a test n tune day, and watch those cars run, most of them would be lucky to run mid 13's. But I will tell you this, those cars were smoking the tires almost halfway down the track. I was told this by many old hot rodders and by people who were into drag racing in the 60-70's. We are also talking about full frame, all metal , 4000lbs cars here. These things were tanks, and had insane amounts of tourqe, that could rip stumps out of the ground.
Now the moderm muscle cars of today, cut better 1/4 miles stock, because of the tire technology, and suspenshion technology. If you get a chance pick up a mopar muslce, or a chevy hi performance. Now and then, they will take a bone stock muscle car, and test it at the strip. Then they will add a set of slicks. and watch them e.t.'s drop like a box of rocks.
I love GM's moderm muscle cars of today, but IMO nothing is compares to old American Iron Muscle cars. Back in the 60-70's you had a choice between 3 different types of v8 power plants, 2 types of transmissions, and good choice of rear axel ratios from the factory. Your cars back then could come with 12 bolt , 9inch, and Dana rear ends. I dont know, but I just feel that the old muscle cars were 10X better.
But the old muscle cars, couldnt ride, corner, brake, launch, wiegh, like modern muscle cars do. Back then fuel was alot cheaper, so you could have larger C.I. motors, with poor fuel economy, with big carbs or multiple carbs. Now you have strict emission laws and rules that the factory has to meet. And no longer can these cars come with 11to1 compression ratios.
My whole moral of this stupid speech is, respect the old muscle cars. If it wasnt for them, we wouldnt have our modern fbodies. Respect them, because if you goto your local strips, chances are your 60-70 muscle cars are dominating the 1/4 mile. Respect the old muscle cars, because they were a hell lot easier to work on, and had alot more room in the engine bays!!!!!!!
Ok im done Anyone wanna trade a 97 Formula for a old 60-70's Bowtie in here? lol Im open
Old Dec 10, 2003 | 01:14 PM
  #23
anaik's Avatar
Don't look at the ET's, look at the mph. That is a better indicator of hp at the wheels.
Old Apr 20, 2004 | 05:14 AM
  #24
2ZPOINT's Avatar
Why do you care about having a 350 with the exact same number horsepower as the old ones. You seem to have a mental set that old engines are just better. We tend to stay believing the first thing we hear about a subject ,and you have obviously been told that the old engines were better. Older cars are badass and will have a definite cool factor and vintage nostalgia about them,but frankly newer cars will run circles around them stock for stock. Put unleaded gas and emissions on those old 350s and they will put out less horses than todays. Not to mention they got horrible gas mileage. Have you looked at the headers and air intake on a stock lt1....they suck...thats something you can do right there. I have a stock bottom end lt1,home ported heads,comp 306 cam,hooker long tube headers,and a 50 dollar pcm for less tune and the car runs well in the 11s on motor. Thats with a/c,power steering,and on todays ****ty gas. NO NITROUS ..NO SUPERCHARGER...and I can still drive it on the street everyday. A old school 350 doing that would get like 6 miles to the gallon,and have no creature comforts. I'm not trying to flame you man but you keep asking the same questions. Take your lt1 net horse power and add about 25% and there's your gross. Take in mind thats still through emissions and accessories. My uncles 67 camaro with stock 327,muncie 4 speed,and a few mods like headers,holley double pumper,and No power accessories ran 14.6 at its best. My dad had a 55 chevy...took the bad boy 375 horse 350 you are referring to...added ported heads,a big cam,4 speed on slicks and it ran a 12.07 at its best back in the 70s..that was of course gutted a/c and power. You need to STOP LISTENING TO JOE DIRT IN HIS MULLET MOBILE AND DO SOME RESEARCH. You can find plenty of ways to turn your lt1 into a bad mama jama. Do bolt ons for now ,and that alone will make a big difference on your car. ITS THE AGE OLD QUESTION...HOW FAST DO YOU WANT TO GO...all I can say is that if all you want is to be even with an oldschool 350 horsepower wise...you already got it ...raise your horsepower goals...
Old Apr 20, 2004 | 05:22 AM
  #25
2ZPOINT's Avatar
And the stock cars back then that did run in the 12 on slicks were huge big block motors...You gotta compare it equally...If you want to compare a mopar 426 hemi to something compare it to a "big block" dodge viper.
Old Apr 20, 2004 | 11:05 AM
  #26
mebanditws6's Avatar
Ok, we all realize now the gross hp measurements were more optimistic than the net figures of today. But even still, many engines then were underrated, so even if they were rated in gross form, the ratings weren't really that optimistic.
As for the old LT1's running slower than a modern LT1, that is entirely not true. In bone stock form off the showroom floor with stock bias plus tires, a 70 1/2 LT1 4spd ran 14.1's @ 101-102mph, exactly what a stock 6spd LT1 runs. However, with slicks and open headers, the exact car ran a 12.89 @108mph. Trapping that high on slicks is a sure indicator of the car's potential not to mention the small tweaks such as carb jetting we would consider free mods of today that you could do. Also, the old LT1's had an all forged bottom end, iron block and 4 bolt mains. Sure the new cars run some impressive times but the improvements in tires and suspensions do more than many realize not to mention a 70 1/2 LT1 weighed close to the same as the 03 Cobras which is close to 3800 lbs. My friend's 79 Z28 only has a warmed over 350 out of an 84 3/4 ton truck that puts out a little over 300hp at the crank through 3.42's and a posi and a Hughes TH400. That thing with good tires is still severely traction limited, noticeably worse than a 3.23 A4 Z.
Jason
Old May 11, 2004 | 12:58 PM
  #27
blue's Avatar
Don't trash this guy for posting this question on old muscle cars. I'm 25 and since I was 12 I've heard from almost everyone, "Oh, I remember the old cars...oh they were better... they had 1200 hp stock...oh they could snap your head off accelerating...I remember my old ---blank-- it would jump over buildings and approach the speed of light at top speed...etc."
Hearing this from my dad and everybody else left me thinking that the old cars were better. Anybody growing up hearing this, (and this is almost all you hear, I have hardly ever heard someone say, "get real dad, anything we could build then, we can build now only better") is going to have ingrained in them that somehow older cars were better. It leaves one thinking, and the attitude seems to be an institution in America today, that we had some great car building knowledge back in the day that we have lost, like they knowledge of the greats in Atlantis that was lost never to be regained, and we can't build cars like that anymore.
Of course this idea is stupid but it is what has basically been taught to any young man today by every older man they heard from growing up.
Old May 11, 2004 | 05:01 PM
  #28
BUBBA's Avatar
I'm flabbegasted! Where did you get those ETs and quarter mile speeds?
I would have never guessed that those cars were that fast and I was around when they were.
Are you certain?
Old May 11, 2004 | 06:11 PM
  #29
pelebkf's Avatar
Man It has been since Dec since I posted my last question. I never though this thread would be brought back to life. But I am amazed that I got HAMERED 4 months after my post. Sorry I am not as experienced about older compared to newer cars but I thought this was at least a fair question. Especially for all the rumors of the old generation. But again thanks for all the replys guys. It has been helpful.
Old May 11, 2004 | 06:27 PM
  #30
94NDTA's Avatar
Another thing I think people are missing is that a lot of todays motors are underated as well. LT1 somewhat, but the LS1 more so. They are also underatted using net hp instead of gross. I wonder what the gross hp of an LS1 would be? Ibet it would be the same or better than any old school small blocks factory with twice the reliability and gas milage. My dad use to be big into oldschool muscle back in the days. I let him drive my LT1 and he said it was one of the fastest car he has driven (for a street car) He actuallt helped build a race track near here and worked there. It's still here too.
