What is a good true dual muffler?
Old Jun 7, 2006 | 05:56 PM
GnarlyZ28's Avatar
Hi, i recently hooked up my tsp x system with bullets and kooks headers up to my car. I have no emisions or cats and the vibrations are getting annoying. What would be some good mufflers to quiet this thing down and stop the vibrations without compromising any flow or HP?
Thanks,
Jeff
Old Jun 7, 2006 | 06:01 PM
blkchevyz's Avatar
Re: What is a good true dual muffler?
i put a couple flowmaster 1 chamber race mufflers on and it helpped alittle.
i was running dynomax 3 inch bullets
also how do you have the tips angled. make sure there not strait down.
Old Jun 7, 2006 | 08:05 PM
Jameslt1TA's Avatar
Sweet thunder mufflers sound awsome. They're not the quietest, but my setup doesn't rattle around. Are you using rubber muffler hangers?
Old Jun 7, 2006 | 08:19 PM
GnarlyZ28's Avatar
The hangers are like a cube of rubber wrap inside the metal hanger. Does anyone know if pointing the the tips away from the ground would make a noticeable difference in the noise?
Old Jun 7, 2006 | 08:45 PM
sam pace's Avatar
if you really want to quiet it down, turn your tips away from the ground to the side and run an extention to run in front of the tire.
once you get the sound away from under your car it will be real quiet except for the roar comming out the side
Old Jun 7, 2006 | 08:47 PM
tyrsmkr's Avatar
Yeah just turn them a bit so that they point sorta sideways instead of just strait down.
Old Jun 7, 2006 | 10:56 PM
GnarlyZ28's Avatar
sounds good, ill give it a shot tomorrow and let you know what happens.
Old Jun 8, 2006 | 12:09 AM
speed_demon24's Avatar
Spiral flows run out the back under the axle here. Not too loud at all inside the car, no drone or anything.
Old Jun 8, 2006 | 07:02 AM
teke184's Avatar
magnaflow 4x9" straight throughs....turned my cammed/LT/no cat car into a ***** cat at idle.
you can hear the lope of the engine over the tone of the mufflers.
they still flow great, are stainless, and and compact (same thickness as bullets)
Old Jun 8, 2006 | 07:19 AM
Sweetred95ta's Avatar
I have Flowtech Afterburners and I don't get really any extra noise. The problem is they're so big, that I'm having ground clearence problems that I'm going to have a muffler shop try and fix.
Old Jun 8, 2006 | 10:56 AM
Honda Hunter's Avatar
I want to a with a chambered muffler. Sweet thunder doesnt make a 3.5 though.
Old Jun 8, 2006 | 12:07 PM
Gripenfelter's Avatar
Dynomax ultra flows or Magnaflows.
I have magnaflows on my duals but had to "massage" the floor.
http://web.camaross.com/forums/showthread.php?t=452678
Old Jun 8, 2006 | 02:14 PM
My friend has those on his car and they scrape on the highway through dips. They are teh same thickness as a bullet, but you can't tuck them up in the tunnel like a bullet style muffler. And his car sounds too buzzy with them.
Old Jun 8, 2006 | 02:45 PM
blkchevyz's Avatar
http://www.mofbody.com/blkchevyz/mufflers.JPG
thats what im running.
they are only 1/2 an inch taller then the bullets
Old Jun 8, 2006 | 05:17 PM
Jlo's Avatar
Jlo
Are those flows?? what's the part number??
