what to get with 40 dollars?
i have a 3 inch heavy duty cut out ill sell you for 27.50 shipped. pm me if interested. you can make it fit on your stock pipes, i got it off a 305 camaro with 2 1/4 inch i-pipe. it just had flairs to make it fit, sounded good still.
Go in halfs with someone on a set of airbags for the rear springs. Put one in your rear pass side spring and have the other person do the same on his/her car. Kits out of Summit come with all the lines and fittings for both bags.
Seriously $40 can get you: A drop in replacement K&N filter, 4-10 HP increase or TB Air Foil, 2-4 HP increase or used Underdrive Pulley, 2-5 HP increase or Synthetic Oil, 2-5 HP increase or some nice spark plugs, 10HP increase.
A tune-up
