what gears do i have?
Old Apr 1, 2004 | 05:59 PM
Allwaysbroke Z's Avatar
Question what gears do i have?
How do i know what gears i have in my 1995 z28? Its a 6spd btw..
Old Apr 1, 2004 | 06:01 PM
Bow94z's Avatar
from the factory they are 3:42's with the six speed.
if you think you have different gears from a previous owner, get a professional to open up the rear end and see what ya have in there.
Old Apr 1, 2004 | 06:02 PM
Tires_Smokin's Avatar
I found a hamster and treadmill in mine. Kinda looked like the same hideous thing I saw on the Quiznos commercial. Anyhow, A4 I think has 2.73 and M6's have 3.23. Someone correct me if I am wrong.
Old Apr 1, 2004 | 06:04 PM
jdizzell's Avatar
Factory M6--------------->3.42
94ZGRNMCHN's Avatar
I have a 6-speed and mine came with 3.42, got 3.73's now.
Old Apr 1, 2004 | 06:05 PM
One says 3.42 One says 3.23 uhm.. which one is it? and how much of a difference is there? ANDDDDDDDDDDDD what would be a better gear? or do you think those ratios are good?
Old Apr 1, 2004 | 06:07 PM
chy20k1's Avatar
factory 6 speed is 3.42, auto was either 3.23 or 2.73
Old Apr 1, 2004 | 06:18 PM
It's 3.42. Look at your RPO code sticker.
GU2 : AXLE REAR, 2.73 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
Old Apr 1, 2004 | 06:34 PM
warwickbass's Avatar
My auto '95 Z28 has 3.23.
Old Apr 1, 2004 | 06:36 PM
Sorry about the confusion, he must of posted that before mine since we posted at the same time it appears. I guess I made an error on the M6, woops..
Old Apr 1, 2004 | 09:30 PM
Bow94z's Avatar
Replacing your factory gears......
For 6spd, 4:10's are good gear..(best bang for the buck$!)
autos, 3:73's are not bad..but im not sure how 4:10's would do on a A4
Old Apr 2, 2004 | 12:21 AM
CamaroSS30thAnn's Avatar
word
him and shoebox are right
Old Apr 2, 2004 | 12:25 AM
stonez96z28's Avatar
Someone help me out here, but If cruising along at 70 mph in fourth gear with an M6 you can tell by reading what your tach is saying?
Old Apr 2, 2004 | 12:42 AM
i believe if u have higher gears u will cruise at a higher rpms.......correct me if im wrong
Old Apr 2, 2004 | 07:43 AM
Use this and you can see what your rpms are for different speeds.
http://www.f-body.org/gears/
