What gaskets DON't need RTV????
Old Oct 9, 2003 | 12:01 AM
S.J.S.'s Avatar
Throwing my motor back together and some guys put RTV on stuff that some don't. Just wanted your guys opinion. What gaskets really DON't need any or shouldn't have any?
Old Oct 9, 2003 | 12:16 AM
atljar's Avatar
I RTV everything except for oil pan, headers, valve covers and heads. Intake only gets it along front and back of block.
Old Oct 9, 2003 | 12:23 AM
94formulabz's Avatar
I used RTV spareingly on my EGR hose because i didn't have another gasket. Front and back of the intake manifold. I also put a dab in the corners of where the oilpan seal meets the timing cover and where i partially tore my oilpan seal Everywhere else i used conventional gaskets on CLEAN surfaces
People tend to think more is better and then it squirts out when you bolt stuff down and gets into your oil passages ect, don't do that
Old Oct 9, 2003 | 12:26 AM
madwolf's Avatar
Ditto, except throttle body main gasket and I also use LOTS of Permatex Copper Hi temp sealant especially in the back of the intake around the oil pressure sensor bolt.
Old Oct 9, 2003 | 01:28 AM
atljar's Avatar
Forgot about TB gasket, no RTV there either.
Old Oct 9, 2003 | 01:33 AM
Me three
Old Oct 9, 2003 | 02:20 AM
96 WS6's Avatar
I use ultra copper on my header gaskets
Old Oct 9, 2003 | 07:58 AM
93ZM6Tally's Avatar
I agree except that I did use a small amount of RTV just to hold the oil pan gasket in place when I put the pan back on with the engine in the car. If your engine is out putting it on completely dry would be the way to go, providing everything is squeaky clean. Get the front or the back of this gasket off just a little and it will leak oil like you've forgot to put the oil drain plug back in.
Old Oct 9, 2003 | 10:43 AM
Compstall's Avatar
I put the throttlebody gasket, waterpump, and rear end cover gaskets on dry.
Old Oct 9, 2003 | 11:00 AM
Hyperspeed97z28's Avatar
I rtv'd dabs on all of my gaskets...
Old Oct 9, 2003 | 01:22 PM
S.J.S.'s Avatar
Your telling me you guys even put it on exhaust, head and intake gaskets???
Old Oct 9, 2003 | 01:42 PM
I used a Little on the intake and tons on the front n back.. and a little on my exhuast gaskets too..
Old Oct 11, 2003 | 05:10 PM
slverbullet's Avatar
what about using spray on sealant on some of the gaskets? when i just did my intake manifold gaskets i used some copper spray on sealant because i heard you can have leaking sometimes between ports. i probably didnt have to worry about this and i'm sure this is more true about higher compression motors. however, i didnt see that it would hurt anything and i would rather be safe than sorry. just personal preference.
Old Oct 11, 2003 | 06:37 PM
Pro/Street SS's Avatar
Smile
No gasket needs RTV, .... RTV (Ultra Copper) the front and back of the intake, and the header gaskets, put the rest on dry, you can copper coat (spray) the head gaskets ......JMHO
After being a engine builder for over 29 years we learned a lot about what to use and what not to use, again JMHO !
Many things don't even need a gasket, RTV works just fine, Notice that the factory is going to useing more RTV then in the past, I myself only use Ultra Gray or Ultra Copper, both work very well
The best advice anyone can give another doing any type of work with gaskets is, Use The Torque Specs Even For The Smallest Of Parts!!!!
John
Gator Transmission
Old Oct 12, 2003 | 08:39 PM
S.J.S.'s Avatar
You dont put RTV on anything??????
