What gas with 383??
Re: What gas with 383??
What are the head chamber CC's,The head gasket thickness,how far is the piston in the hole(was the block decked?). What is the ICL or is the cam installed on a 113 or is it +4*?
Originally Posted by Mike96z
Thanks guys, had a old timer tell me today that it pump fuel won't support anything over 10.1:1 -10.3:1. Nothing against old people, they builld fast *** carbed cars. Thanks
Heads are stock CC's just cleaned up and pistons are +7cc, head gasket is stock thickness, block is stock decking height the cam is 113 but i will have it tuned and timing changed. Pistons are 9.6-11.7:1 ratios <----- specs
i have a tune from PCMForless and it is tuned to run on 93. It costs alittle bit more at the pump but after seeing what my motor looked like running on 87 its whole life there was alot of sutt in the heads and intake.
CARiD
Jul 7, 2015 08:19 AM
