What gap for TR55 plugs
Old May 17, 2003 | 02:52 PM
atljar's Avatar
I just bought a set and gapped them at .050, and the car runs like crap now. It is missing badly.
What gap is everyone running with NA apps and these plugs. I have asked two "experts: around here, one suggested .043, the other .030. I was thinking about going in the middle, maybe ...035ish So....you all are the tie breakers!
Car is all bolt ons possible, plus a big cam.
Old May 17, 2003 | 04:32 PM
ur2slow's Avatar
I gapped mine at the factory .050 and everything runs fine.
Old May 17, 2003 | 09:24 PM
Hyperspeed97z28's Avatar
also gapped at .50 runs great
Old May 17, 2003 | 09:45 PM
hvyss's Avatar
I gaped mine ( when I ran them )at .50 with no problems. I don't mean to sound stupid or redundunt but are you sure you have all the plug wires to the right cylinders? Sounds like you have a plug wire backwards which will cause the car to miss. Good luck!
HVY SS
Old May 17, 2003 | 11:07 PM
atljar's Avatar
Ya i know they are all on the right cyl. I did the wires 1 at a time to make sure of that.
Guess im gonna go back in and lessen the gap a little, and make sure all the wires are snapped on well.
Old May 17, 2003 | 11:09 PM
Quickshotkimber's Avatar
Did You have any headwork done? I run mine between .040 and .045
Old May 17, 2003 | 11:10 PM
Timberwolf's Avatar
I ran mine at .060, but that was with an MSD 6AL and blaster coil
Old May 18, 2003 | 12:06 AM
atljar's Avatar
No head work, but the cam is a big factor. Its pretty radical and i know it is playing alot with the cyl pressure. 234/242 with lots of lift. Anyways, im using a 6AL box, with a Accel coil.
First things first, ill go under there tomorrow and make sure all the wires are snapped on tightly, and that none of the wires are toasted.
Jared
Old May 18, 2003 | 01:30 AM
Indy93Z28's Avatar
Mine are gapped at .045
Old May 18, 2003 | 08:25 AM
I don't see any reason you would not want to go with the stock gap.
KYWes
Jun 14, 2022 06:52 AM
HarleyZ28
Oct 5, 2015 06:23 AM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
gonzo275rltw
Jul 11, 2015 04:19 AM
