What fuel pressure gauge? 15 or 100 psi??
Old Jan 22, 2006 | 11:53 PM
johnny3986's Avatar
Hey, I am going to be running a fuel pressure gauge inside the car.
I KNOW I KNOW I KNOW...you aren't suppsoed to, and that leaks would be a pain in the rear.
I am going to have a NX wet system hooked up with a window switch, fuel pressure safety switch, and an arming switch.
I don't want it under the hood, and I don't want it on the hood since I don't feel like drilling or marring the stock hood.
What gauge? 100 or 15psi? I am thinking the 15psi makes more sense.
Old Jan 23, 2006 | 12:01 AM
Compstall's Avatar
Re: What fuel pressure gauge? 15 or 100 psi??
15 psi isn't enough, as your car runs stock @ 40+ psi. You'll need the 100 psi gauge, and they do make electric gauges so you don't have to run a fuel line inside the car.
Old Jan 23, 2006 | 12:08 AM
johnny3986's Avatar
Where would you hook the fuel pressure gauge up at?
Old Jan 23, 2006 | 12:10 AM
Compstall's Avatar
Right off the fuel rail.
Old Jan 23, 2006 | 12:13 AM
johnny3986's Avatar
I know that a mechanical fuel gauge would hook up off the Scraeder valve, but...
Even the electrical ones? Do they just have a mechanical to electrical or is there a wire you can splice in elsewhere??
Old Jan 23, 2006 | 12:24 AM
Compstall's Avatar
I have never dealt with one personally, but I believe the electrical style's sending unit mounts to the fuel rail, then the wiring from there runs to your gauge. BTW, it basically IS a mechanical signal to an electrical signal.
Old Jan 23, 2006 | 12:28 AM
johnny3986's Avatar
Sounds good!! Thanks for your help! I really want to do this right and obviously, I don't know everything and I appreciate it.
If anyone else reads this and knows if the Autometer Ultralite Gauges come in an electrical version of the 100 psi gauge, let me know where to get it!!
Thanks!!
Old Jan 23, 2006 | 12:35 AM
Compstall's Avatar
Old Jan 23, 2006 | 12:38 AM
johnny3986's Avatar
Yeah, I found it on ebay. Is it electrical? Is it mechanical?
I am looking for it too right now, and will post if I do . If you figure it out before I do, be sure to let me know!!
Old Jan 23, 2006 | 01:32 AM
Compstall's Avatar
It's electrical.
Old Jan 23, 2006 | 01:34 AM
johnny3986's Avatar
Sweet. So its got one of those mechanical fittings that goes on the fuel rail, then converts it to an electrical signal that is then sent through the firewall and in to my gauge correct?
Where did you find this info at??
Old Jan 23, 2006 | 07:44 AM
Compstall's Avatar
Being an aircraft mechanic for 13 years tends to help.
Old Jan 23, 2006 | 08:17 AM
Heatmaker's Avatar
Advanced Member
The complete kit is about $149.99 from summit... or ebay. It's much safer than running a live gas line at 40+ psi into your cockpit. Vaccum gauge yeah okay... fuel line.... Never. I have one, it's damn accurate too.
Old Jan 23, 2006 | 10:05 AM
johnny3986's Avatar
Yeah, this was after a 12 hour work day on top of some pretty hard partying the night before and I was being lazy. I got on to Summit and found what I was looking for. Ebay as well Thanks for the help you guys!!
Old Jan 23, 2006 | 10:39 AM
JB94's Avatar
Stewart Warner also has a 0-100 psi electric guage that includes the sending unit for about $90.00.I installed one of these in my car and it works well.It's not a full sweep version but I don't plan on doing any professional racing any time soon.
