What fuel
What fuel
I was wondering what octane fuel you guys recomend for the car in sig
I compression ratio is 13.6:1
I am running 110 unleaded right now but would like some other thoughts
thanks
Dave
thanks
Dave
You have to base fuel selection on the dynamic compression ratio (DCR), not the static compression ratio. Have you calculated your DCR? Part of tuning an engine like that would be to try various combinations of octane, ignition advance and A/F ratio to find the one that optimizes power.
as far as dcr I have no idea
Why did you start with 110 unleaded? What 110 unleaded are you running.... I couldn't find anything over 104, until a couple weeks ago when someone posted a link to an obscure source of 110. Why are you using unleaded? Did it show signs of incipient detonation on the plug insulators when you advanced the timing with the 110? Air race fuel is typically highly leaded.
There are online calculators available for DCR.
http://www.proracingfuels.com/Product_MARK3.html
they have 114 unleaded too
http://www.proracingfuels.com/Product_MARK5.html
