what is the easiest way to check push rod lenght?
Old May 13, 2010 | 07:15 PM
z28beast's Avatar
ok so i ordered a push rod checker from comp cams...its good from 6.8 to like 7.5.... im wondering what is the easiest way to check for the right push rod length? im hearing stuff about having to use a flat tapet lifter and that i can use a roller lifter and im confused as hell??? i do have a full set of my "old lifters"
Old May 13, 2010 | 08:35 PM
wrd1972's Avatar
http://www.lmgtfy.com/?q=checking+pu...ength+geometry
Start here. For best results, you want a solid lifter or a converted to solid lifter. If you dont use a solid lifter, IMHO, it will slightly skew the findings a little or a lot. I would pull the intake and do it right.
I like using dry erase marker or ring pinion gear marking compound on the tips to check the patterns.
Ideally, you want minimal sweep and a centered pattern but you will find there has to be some balance. As the pattern moves more toward the header, typically the sweep will decrease. Just dont go too far.
Post some pattern pics and we can comment.
Old May 13, 2010 | 09:11 PM
z28beast's Avatar
ok i will... i forgot to mention my engine is outta my car on a stand
Old May 14, 2010 | 05:00 AM
Guest47904's Avatar
Guest
Comp Cams tech page is very good for what you need
valve train geometry by Comp Cams
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
ModdedNerd
Feb 5, 2015 04:37 AM
alphaauto
Jan 23, 2015 07:42 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
