What Are The Easiest Ceramic Shortties To Put On
Old Aug 30, 2004 | 08:10 PM
nico z28's Avatar
Any Thoughts
Old Aug 30, 2004 | 08:18 PM
S8ER95Z's Avatar
Re: What Are The Easiest Ceramic Shortties To Put On
The BBKs I put on were pretty easy..It would require pulling the drivers side motor mount bolt and jacking the motor up a lil. Which honestly takes no time at all.
Old Aug 30, 2004 | 10:01 PM
Bud M's Avatar
Hooker shorties don't require jacking up the motor or removing the motor mount but you do have to have their flange welded onto the cat. But I did have to separate the steering shaft. Plus my y pipe had to be "adjusted" to fit right.
Old Aug 30, 2004 | 10:12 PM
Kataklysm's Avatar
MAC mids go right in with no troubles.
Old Sep 2, 2004 | 01:04 AM
'97SLVRBullet's Avatar
My Edelbrocks made me curse a few times but it isn't that bad. But the y-pipe that comes with it doesn't bolt right up to your stock pipe(3") you are single cat right? My car is/was duel cat and I got the single cat headers, that may have been the problem. I didn't want 'em anyway so I just cut a 3" pipe from my y to conect to were i cut the second cat off.
Old Sep 2, 2004 | 06:42 AM
97ss497's Avatar
SLP's are not too bad; the forwardmost passenger side bolt is the worst.
Old Sep 2, 2004 | 11:24 AM
S8ER95Z's Avatar
Thats why I jacked up the motor, it was hitting the steering shaft and only needed maybe an inch to clear it. I tried to seperate the shaft but it proved easier for me just to wiggle out the mount bolt and pump the jack a few times.
carguy0119
Apr 11, 2016 11:11 PM
WildRidez
Mar 27, 2015 08:22 AM
BPS
9
Mar 5, 2015 10:51 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
Renegade Toker
Jan 23, 2015 10:27 PM
