what dual valve springs for the 306 cam?
Old Oct 11, 2007 | 07:41 PM
mvvette97's Avatar
Just wondering what everybody is using with the 306 comp cam. I don't like the 918 that comp says to use because I broke 8 out of 16 on my LS1. What is a good dual spring?
Old Oct 11, 2007 | 07:55 PM
blueformula350's Avatar
Why not go with some single beehives from pac?
Old Oct 11, 2007 | 07:58 PM
mvvette97's Avatar
well I just don't trust the single spring anymore since they just about destroyed my LS1. I like the piece of mind with a daul spring
Old Oct 11, 2007 | 07:59 PM
raroz28's Avatar
dual springs can break too.
Old Oct 11, 2007 | 08:01 PM
mvvette97's Avatar
very true but with a dual you have one more spring to hold the valve from bashing the piston. Normally both of them don't break
Old Oct 11, 2007 | 08:08 PM
SS RRR's Avatar
Go to Comp's website and see what they recommend.
Old Oct 11, 2007 | 08:35 PM
9formula4's Avatar
They reccomend their products.
Old Oct 11, 2007 | 09:21 PM
hotrod18_69's Avatar
I'm using Crane 10308 spring kit.. I've used them on a few LT1 builds. .Worked great.. Never had any problems yet..
Old Oct 11, 2007 | 09:23 PM
mvvette97's Avatar
Are they a direct fit on the stock heads?
Old Oct 11, 2007 | 09:34 PM
Yes DIRECT FIT.. Just put them on..
http://store.summitracing.com/partde...0&autoview=sku
Old Oct 11, 2007 | 09:35 PM
mvvette97's Avatar
Sweet, I guess I'll get those, thanks
Old Oct 11, 2007 | 09:36 PM
Yup.. No problem..
Old Oct 11, 2007 | 09:59 PM
Stl94LT1's Avatar
You can put a 1.460 OD spring on a stock head? No machining?
Old Oct 11, 2007 | 10:03 PM
mvvette97's Avatar
what size is the OD on the stockers?
Old Oct 11, 2007 | 10:16 PM
Stl94LT1's Avatar
1.334" for the stock LT4 spring.
