What do you use in your T-56?
Old Nov 16, 2003 | 07:25 PM
zx1216's Avatar
I'm going to change my trans fluid soon so what do you guys recomend?
Old Nov 16, 2003 | 07:27 PM
96z's Avatar
96z
Honda ATF.
Old Nov 16, 2003 | 07:30 PM
zx1216's Avatar
my bad, i didn't see the poll, can you buy honda atf at parts stores?
Old Nov 16, 2003 | 07:41 PM
Heatmaker's Avatar
Advanced Member
Mobile Synthetic ATF and a Prolong-Tranny treatment
Save the Honda stuff for the lawnmower
Old Nov 16, 2003 | 08:43 PM
zx1216's Avatar
any one else?
Old Nov 16, 2003 | 08:49 PM
Hyperspeed97z28's Avatar
Regular dextron, the stuff the label on the tranny says, had honda fluid before that, no difference....
Old Nov 16, 2003 | 08:56 PM
stereomandan's Avatar
I put in regular Dexron III. "If it ain't broke, don't fix it." I just changed mine yesterday and noticed a nice difference between the original fluid that was 60,000 miles old, and the new Dexron III that I put in there. There is no need for synthetic.
Dan
Old Nov 16, 2003 | 08:58 PM
F Carline 94's Avatar
Mobil 1 Synthetic ATF
Old Nov 16, 2003 | 09:01 PM
turbo_Z's Avatar
i replaced my original fluid with Honda ATF a while ago but now i just run Mobil 1 syn. and it feels exactly the same, plus you dont have to walk into a Honda dealership to get it.
Old Nov 16, 2003 | 09:09 PM
b84camLT1's Avatar
Royal Purple Dextron III here. GM doesn't even recomend chaning the fluid untill like 100k or some ****. From what i've heard RP and Redline are the best fluids out there. Why not spend a few extra bucks when you aren't going to do it that offten anyway?
IIRC Napa stocks it and it's about 6 bucks a quart.
Old Nov 16, 2003 | 09:15 PM
Heatmaker's Avatar
Advanced Member
To tell you the truth jut put in some Good ATF DEXRON 3 anything fluid. I mean it will fill the same either way... fluid is fluid. Tranny fluid is different from the motor oil...if you swap motor oils you can tell the difference. You switch the tranny stuff out feels just the same...unless you have really bad tranny fluid in your car and have had it in there twice it's life cycle (recommended change every 30K miles).
:blah:
Old Nov 16, 2003 | 09:20 PM
93Z286Speed's Avatar
Honda ATF here
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
treyZ28
Mar 28, 2003 01:03 AM
GreenMonster138
Classic Engine Tech
Mar 26, 2003 02:14 PM
VentsWoker
West South Central
Nov 17, 2002 03:29 PM
