what do you think. does a msd box cure opti
Old Apr 18, 2006 | 07:19 PM
hulettsz28's Avatar
What are your opinions? Those of you that have installed and used an MSD aftermarket box or one similar to it, do you think it fixed your failing opti (if failing at all) or WOULD help limp a failing opti along? Kind of a band aid. post away
Old Apr 18, 2006 | 07:21 PM
Z28LT1_Just_Nasty's Avatar
Re: what do you think. does a msd box cure opti
I have one on mine, overall it just seems like sturdier construction. If your going to replace parts might as well upgrade.
Old Apr 18, 2006 | 07:33 PM
izzyz28's Avatar
If anything I think a box could make a failing OPTI completely fail more quickly. With increased voltage/multiple strikes comes more arcing, and the box still uses the signal provided by the OPTI.
Old Apr 18, 2006 | 07:49 PM
97FormulaWS-6's Avatar
I would have to agree with the 2nd reply. What typically fails in the opti is the dielectric between the high-voltage lines in the cap. By adding more voltage, you're just going to make this problem even more pronounced and happen faster.
Old Apr 18, 2006 | 10:13 PM
An ignition box is not going to cure any opti problems. I have been running an MSD box for many years and have not seen any evidence that it contributes to any early opti failure.
Old Apr 19, 2006 | 09:36 AM
WS Sick's Avatar
I ran an MSD-6A on my 93 for about 7 years and my opti never failed until I changed my water pump in 2000.
You could tell a difference above 4500 rpm with it though when the opti did go bad, it ran worse with the MSD connected then. But with a good opti it was as smooth as could be.
mr28
Apr 20, 2016 05:44 PM
ModdedNerd
Feb 5, 2015 04:37 AM
mr28
Nov 23, 2014 11:11 AM
