What do you Know?
Old Nov 18, 2005 | 09:03 PM
projectcam's Avatar
What do you Know?
I installed a set of scorpion rockers in my 97 and am missing one. I ordered one and they sent me a non self aligning rocker. Can I use this on my Lt1. I read somewhere that those are the only ones you can run?(Self Aligning) Does anyone out there have any special tricks on how to remove the fricken crank hub. I have gone through 4 craftman pullers and that thing hasnt budged.(besides soaking it with oil/lubricantes, I already tried that.
Old Nov 21, 2005 | 09:50 AM
projectcam's Avatar
Re: What do you Know?
Come on now Fellas, I still havent pulled that crank Hub off but I can figure that out. The real question is can I use a roller rocker without a self aligning tip? Sombodys gotta know this. Btw, its for an 97 Z
Old Nov 21, 2005 | 10:05 AM
Sandman_97Z's Avatar
I could be wrong, but everything I've read says that the scorpions are all non-self-aligning...
Old Nov 21, 2005 | 10:08 AM
projectcam's Avatar
I have a set of aligning rockers with the guides on the tip. They sent me one without the guides and I just need to know if I can use it or not.
Old Nov 21, 2005 | 10:14 AM
Ok I guess I'm wrong
sorry I was no help....good luck
Old Nov 21, 2005 | 10:17 AM
Crazy95Z's Avatar
If it is a NSA Rocker, then no you can't use it! Send it back and get the right part.
As for the crank pully, it has a lip on the inside where you put the middle piece, so if you don't have something inside the crank snout to press against, then you will just be trying to pull off the balancer while you're pushing against it. So get a 4" allen head bolt that's skinny enough to go inside the crank snout and that works the best.
Old Nov 21, 2005 | 10:20 AM
1SlowFormula's Avatar
Follow the instructions in here to get the hub off, you will need to get an extra long bolt to help you get it done...
Old Nov 21, 2005 | 11:00 AM
SoloExceptional's Avatar
It took me an Air Hammer a Pry bar and about 4 hours to get my balancer off
Old Nov 21, 2005 | 11:05 AM
blazzinbird's Avatar
took me 1 min to get mine off, using a 3 finger pully puller and a are gun
Old Nov 22, 2005 | 11:29 PM
projectcam's Avatar
Thanks for the replies guys, I really apreciate it! I Broke my seventh puller before I figured out I was pushing off of the hub the whole time. . Maybe next time someone searches this topic they can learn from my mistake. I ended up just sending that rocker back because I didnt want to risk anything going wrong. Thanks again
