what do you guys think she'll do
Old Apr 21, 2005 | 05:34 PM
spcearle's Avatar
ok heres what i have in the works and just wondering what it can do so far b4 i keep goin withit....i have a 96 camaro that has a 383 built for it....its a forged 4340 balanced crank/manley h-beam 5.7rods/speed pro lightweight pistons/custom ground cam i think specs are like 220/230//ported heads and valve job/1.6 crane gold rr/double springs/58mm twin tb/ported intake to match heads and throttle body/30 lb injectors/255 fuel pump/pacesetter lt's w/matching ory/slp lm out back/2400 stahl converter/4l60 beefed up/transgo kit/stut tower brace and multipoint subframe connectors/better ignition parts fe nkg titaniums-accel wires new opti.....any ideas what she'll do pending me not breakin the stock rear right off the bat...lol...btw 2.73 stock rear end...just waitin till i get a lil more cash to buy a 3.73 9'inck or 12 bolt...oh yeah dont know if it will help or not but a functional ram air hood with factory box and holly filter to breath it....let me know what you guys think she can do on street 18"kumho tires and what ya think i can do next after the rear end
Old Apr 21, 2005 | 05:35 PM
spcearle's Avatar
Re: what do you guys think she'll do
oh yeah and forgot a fast chip tuned comp to get everything workin together right
Old Apr 21, 2005 | 06:21 PM
#7's Avatar
How do I think it'll do? I think a 383 will do fine I dont have any numbers for you...it'll be badass though!
Although (I'm no expert mind you) I have done my share of searching cam ,injector,tuning type stuff here we have a great search funtion here. In general I think the size cam you plan is considered small for a 383. The injectors are not big enough. 2800 stall maybe. And about your old 273 rear your right it'll blow very soon after if your a lead foot. You should plan the rear with the motor or you may have down time again later. Good luck and thanks for going over seas for us
Old Apr 21, 2005 | 06:56 PM
spcearle's Avatar
this was the biggest bombo i can run right now with the emmission crap i have up here in ny and until i can figure out which base i'm gonna end up choosen if/when i go active for good.....and with this car i plan on just enjoyin it for now till i can get the rear done in it...just wonderin opinions on what this will do
carguy0119
Apr 11, 2016 11:11 PM
blac94Z
29
Mar 25, 2015 04:21 PM
steve10358
Middle Atlantic
Mar 20, 2015 04:50 AM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
