What do you guys think of this setup?
Old May 3, 2007 | 10:48 AM
Azthrei's Avatar
I'm getting really close to finishing my project, after 2 1/2 years in the making, and would like to get some idea's from you guys as to what you think it'll be like.
1995 Firebird Formula
Engine - 396 LT4
LT4 ported intake matched to heads
AFR 227cc LT4 heads with 76cc chambers, running 11.2:1
Comp cams custom grind, .254 .266 @.050 and .622 .638 112 LSA
Ross forged pistons, and forged 6" rods
Callies Racemaster forged crank
LT1 block, bored 30 over, clearanced for 3.875 crank, making 396 roughly
splayed 4-bolt mains
Bosch 42# injectors
AS&M Monoblade throttle body
Jesel comp series shaft mounted rocker system, with tie-bar lifters
Exhaust -
Jet Hot ceramic coated headers, with off road y-pipe
No cats
QTP electronic cutout
Corsa Catback with premium pro series tips
Tranny - T-56
Rebuilt with performance upgrade rebuilt kit
-with new blocker rings, billet keys, 3-4 steel shift fork, etc.
Custom aluminum driveshaft good to ~1200hp
Rearend -
Moser 9 inch rear, 3.75 ratio
strange aluminum case
33 spline axles
detroit true trac
Suspension -
UMI torque arm, with cross brace, and driveshaft safety loop
UMI double diamond SFC's
UMI double adjustable panhard bar
BMR boxed LCA's
BMR upper panhard relocation bar
Hotchkis strut tower brace
New bilstein shocks
Eibach prokit lowering springs
I might have missed a few things, but that gives a general idea of the setup. What do you guys think of it?
Old May 3, 2007 | 10:58 AM
BUBBA's Avatar
Monster.
Old May 3, 2007 | 05:43 PM
FASTFATBOY's Avatar
You are leaving a good bit on the table with that low of compression ratio...I would check the dynamic compression to see where its at...do a search.
Needs a 4.11 or a 4.30 gear.
If you ever put that car on slicks and launch it and it hooks, say bye bye to that aluminum center section.
No frame conectors?
David
Old May 3, 2007 | 06:14 PM
Azthrei's Avatar
I chose the 3.75 gears because it's not going to be a straight all out race car. It'll probably see about half and half, of street and track use. With the monster engine, I still would like to get a little bit of gas mileage out of it while driving around.
Also, what do you mean by frame connectors? Never heard of them.
Old May 3, 2007 | 07:02 PM
2000GTP's Avatar
Looks like a strong, solid setup. Hate to see what the grand total tallied up to.
Old May 3, 2007 | 07:41 PM
SS MPSTR's Avatar
cubic dollar set-up, for sure. should run really strong once dialed.
Old May 3, 2007 | 09:42 PM
JAKEJR's Avatar
11.2 CR with 76 chambers? Are your pistons domed; thin HG?
What am I missing here?
Jake
Old May 6, 2007 | 09:59 PM
Azthrei's Avatar
Using a pretty thin fel-pro gaskets, and slightly domed Ross pistons.
Old May 6, 2007 | 10:14 PM
Heatmaker's Avatar
Advanced Member
What will it be like????? well....let's see.....
how about....
Fast... Scary.... and Holy freakin sssssssshhhhhhhhh**********!!!!!
Wait... I should make that into a bumper sticker!!! hey... no one steal my idea okay.
Old May 7, 2007 | 01:04 AM
Azthrei's Avatar
I've gotten the engine and tranny in over the past few days, with the help of some awesome friends, and the exhaust. Just bolting up all the little stuff, accessories, wiring, and then wiring up the MSD ignition and Meziere pump. Hopefully, if I can get things hooked up over the next day or so after work, i'll be able to start it up come tuesday night or wednesday.
Old May 7, 2007 | 09:51 AM
mitch_cube's Avatar
With all of that 3.75s aren't going to be the make or break on your gas mileage. And my brother's 94z with longtube headers, cai, no cats, gmmg chambered exhaust and 4.10s got better mileage on I-80 between illinois and des moines, ia than my '02 taurus. We filled up in illinois, and in des moines put 7 gallons in his car and 8 gallons in mine.
Frame connectors connect the front and rear subframes since a camaro is not a full frame car. Get some with that kind of power, unless you like stress cracks.
Old May 7, 2007 | 01:43 PM
SS MPSTR's Avatar
He's got them. UMI's.
Old May 7, 2007 | 03:48 PM
Azthrei's Avatar
Ya, i've got the UMI double diamond SFC's.
Old May 7, 2007 | 05:10 PM
FASTFATBOY's Avatar
Woops sorry on the frame connectors.....but I will tell ya....that car will be a WHOLE lot more fun with a 4.11 or a 4.30 gear...with a double overdrive 6th gear it won't hurt that much. Besides who cares about gas mileage at this point? You spent ALL that money to have fun.....right?
And make sure the rear swaybar is back on the car, with a 9 inch it is hard to get the swaybar back on, it can be done..I did it. Without it it will drive and handle funny.
David
Old May 8, 2007 | 01:58 PM
Azthrei's Avatar
I'll be getting some new sway bars as well once I get the engine broken in, and then put in the moser 9 inch. With those sway bars i'll also be getting the relocation brackets for fitting that rear, so things will be much more fun. This whole project has taken just over 2 1/2 years so far, and i've yet to hear her run since back in 05'. I'm really anxious to hear it, let alone drive it around.
