What to do when replacing lifters?
Old Apr 27, 2005 | 10:52 PM
Huntr1117's Avatar
Question What to do when replacing lifters?
My lifters are making alot of noise now and I'm thinking about replacing them. What all do I need to do to replace them? Can I just replace the lifters without replacing anything else? Which lifters should I go with, Comp? I was also planning on installing roller rockers at the same time. I wish that I had the extra cash to do alot more, but lifters and roller rockers are all that I can afford for the time being. Any suggestions will be great. Thanks
Old Apr 27, 2005 | 10:55 PM
1racerdude's Avatar
Re: What to do when replacing lifters?
Try having them adjusted or adjust them before replacing. Go to Shoebox's site and get the procedure.
Old Apr 27, 2005 | 11:02 PM
dover179's Avatar
Old Apr 27, 2005 | 11:56 PM
Huntr1117's Avatar
Ok, I just looked at shoebox's site. Which method do you think works best?
Old Apr 28, 2005 | 12:20 AM
1racerdude's Avatar
If you have no experience with the "spin" method,use the engine running method.
People have had trouble with the spin method,it takes practice.
Put a towel over the rockers to cover the ones you are not doing and only pull one cover at a time.Do it in the yard or put something under the engine as there will be oil spillage,
Old Apr 28, 2005 | 01:07 AM
Huntr1117's Avatar
Is this a common problem?
Old Apr 28, 2005 | 01:09 AM
1racerdude's Avatar
What?
Old Apr 28, 2005 | 01:20 AM
Huntr1117's Avatar
Ajusting the lifters and rocker arms. The tapping noise.
Old Apr 28, 2005 | 10:22 AM
Huntr1117's Avatar
My car has about 115K on it right now. If I do end up replacing the lifters which ones should I go with?
Old Apr 28, 2005 | 12:33 PM
Huntr1117's Avatar
A constant ticking noise that fades in and out that has progressively worse. Also a few shops have told me that it's what the noise is. Even G-Force told me that. I thought that I'd adjust the rockers first.
Old Apr 28, 2005 | 01:06 PM
1racerdude's Avatar
Adjusting the lifters and rocker arms. The tapping noise.
Yes with wear and mileage they will need adjusting.
Old Apr 28, 2005 | 01:59 PM
91RSLT1's Avatar
Am I missing something? He says he is plannning on RR, but everyone is suggesting that he adjust the RR. That will not help the fact that his lifters are ticking, if he doesn't have RR. Replace them, do a search Mindgame just posted some really good info on lifter and how to properly prep them. Then go to shoebox's site for the lt1 specifics from there, as to how to change them.
Old Apr 28, 2005 | 08:40 PM
Huntr1117's Avatar
They said that I can adjust the stock rocker arms to try and stop the noise. If it doesn't fix the noise then I'll replace the lifters and add a set of roller rockers.
Old Apr 28, 2005 | 11:49 PM
whitehooptie's Avatar
Just tear apart the stock ones and clean them out. Also if you get any new ones, just go with the mellings that are sold at autozone. All of the "stock style" lifters are the same.
HectorM52
Jul 30, 2017 11:46 AM
Sauced
Apr 12, 2015 10:18 AM
dfarr67
Apr 10, 2015 07:44 PM
jj_burchiel
Mar 5, 2015 07:05 AM
jayblev95
Dec 1, 2014 06:55 AM
