What Do LT1,LS1 & LT4 Heads Flow??
Old May 30, 2003 | 08:19 PM
Espo's Avatar
What do each of them flow stock and what do each of them flow when ported..
and im talking about a port job from a reasonable priced head porter.. ie. Llyod Elliot
Old May 30, 2003 | 09:10 PM
96z's Avatar
96z
They are ALL over the board. LS1's will outflow LTxs no matter what.
A really good LT1 will do 270ish on the intake 260-265 is very good.
A really good LT4 will do 290 ish on the intake, 275-285 is usually seen.
LS1's are capable of 330+
And as always its hard to compare flow numbers because of the enormous amount of variables in benches.
Llyod Eliot does do good heads.
Old May 30, 2003 | 09:28 PM
Espo's Avatar
thanks for the info..
wow i didnt know ls1s flowed so well.. i thought they were in the low 300s...
Old May 30, 2003 | 09:36 PM
Ai's Avatar
Ai
The best LT1 stuff will usually peak in the higher 27Xcfm range on the internet, and the same in real life. 99.9% of it peaks in the 25X range IRL . Consider you can make up to around 500hp with a HR cam and 270cfm... and almost noone gets close to that.. so maybe something is up
LT4 stuff.. most that I've gotten from other places peaks in the 260-280 range. If you're lucky 280-285. To sit and eek more out of it, you'll usually end up in the 29X with a 2.02 valve.
LS1 stuff isn't going to flow 330, more like around 300 with a 2.02 valve. The 6L truck stuff will get near that with a big valve but the regular ls1 stuff wont. Of course everyone claims that, but again.. the only one I've ever had get over 280cfm was a mandatory cnc head from Lingenfelter. It was huge, but it flowed well .
If you're looking for cheap stuff b/c of a budget, expect 245-255 IRL from LT1 stuff, 255-270ish for LT4 stuff, and about the same for regular LS1 stuff. Based on the heads people have sent in from all over and I've tested myself anyway .
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
