what do i need to install GMPP 1.6rr's
Old Jul 16, 2003 | 09:31 AM
SlowAssTA's Avatar
Question what do i need to install GMPP 1.6rr's
i mean as far as, do i need new valve covers, guide plates, ect...
Old Jul 16, 2003 | 10:38 AM
BUBBA's Avatar
Not familiar with GMPP RRs, but most of the RRs used will fit under the stock covers (sometimes you need to do a little modding to the inside of the covers, but no biggy). You should probably put stronger springs in (consider HOW strong based on whether you plan on installing a cam and use the recommended spring pressures based on that cam.
You only use guide plates if the RRs are NON-self aligning. Self-aligned do not need guide plates or hardened push rods.JMHO
Old Jul 16, 2003 | 11:02 AM
BUBBA's Avatar
Call Sallee Chevrolet. They can probably advise you. They also carry lots of GMPP at good prices and fair S&H charges.
1-800-545-0048
Old Jul 16, 2003 | 01:20 PM
SlowAssTA's Avatar
thanks...
Old Jul 16, 2003 | 02:12 PM
craigffb's Avatar
I got mine from Jason Cromer at Taylor Buick in Ft. Walton Fl. He sells them in a kit with everything you need but the new valve seals. It was $370.25 shipped here to me in Hawaii. No you don't need new valve covers or guide plates. But I did end up getting the LT4 covers because I got tired of the valve noise.
Old Jul 16, 2003 | 04:50 PM
SlowAssTA's Avatar
thank you again... but do you have the 7/16 stud version or the 3/8 stud version...
i have the 7/16 version...
Old Jul 16, 2003 | 11:14 PM
Bud M's Avatar
The rockers should be self-aligning so you won't need guideplates. If your rocker arms are made for 7/16" studs you will need those studs. Stock LT1 is 3/8".
You will need new springs. LT4 springs are adequate and inexpensive.
You may need to modify the valve cover supports for clearance. I did mine with a grinder and a cutting wheel.
Old Jul 17, 2003 | 01:11 AM
craigffb's Avatar
I have stock studs so I got the 3/8" 1.6 rockers and the stock cover worked fine, just kind of noisy. What exactly do you all ready have? That way I can tell you what else you need.
Old Jul 17, 2003 | 06:33 AM
SlowAssTA's Avatar
all i got are the rockers...
part # 12361322
and btw i need guide plates cause these are not the self aligning rockers...
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
94redform
Sep 8, 2002 03:27 AM
Ken95Z28
Aug 21, 2002 04:32 PM
