What is the difference between a throttle body for a '93 as a '97?
Old Jun 7, 2003 | 05:23 PM
REPO's Avatar
Can anyone tell me what the actual differences are for a throttle body off a '93 and a throttle body from a '94-'97?
Can a '93 TB fit a '97??
Thanks!
Reid
Old Jun 7, 2003 | 07:21 PM
$hawn's Avatar
I think the only difference is that a 93 throttle body has a extra little hook for the throttle valve cable to hook on, you should be able to use a 93 throttle body, just wont be able to hook a cable on there.
Old Jun 7, 2003 | 08:51 PM
rpmatredline's Avatar
Yeah, my buddy had a nitrous back fire in his 93 and blew his air induction apart, the butterflies on his throttle body were bent 90 degrees and it was trashed. I gave him my stock one since it was sittin around and he had to weld a piece on for the throttle linkage. that was the only difference.
Old Jun 7, 2003 | 10:38 PM
The 1993 also uses a different IAC that screws in, instead of bolts on. It may be functionally the same, though.
Old Jun 8, 2003 | 04:35 AM
REPO's Avatar
Good info.
Any others with experience?
Old Jun 8, 2003 | 04:07 PM
REPO's Avatar
Anyone?
Old Jun 8, 2003 | 04:29 PM
NOMAD's Avatar
Cool
I think they still use the old TPI style 4 prong square connector. Just buy a 95+ throttle body. It's not worth the trouble to get a 93 and have to add onto the shaft to make it work. If you really need a stock one, email me and i'll make you a deal on one.
Main difference is IAC, throttle linkage, and the fact the blades are at a different angle when closed, mostly due to it being a speed density car I believe..
-Shannon
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
