What did my oil drain plug catch? (pic)
Old Oct 2, 2005 | 08:37 PM
Alex 97Z28 M6's Avatar
So I went to change the oil and found this hanging off the oil drain plug. Can anyone tell me what it is?
About 6 months ago I found another piece like this but it was slightly bent and before I could take a pic of it, my wife threw it away. I guess this is the other half?
Old Oct 2, 2005 | 08:45 PM
swemdog's Avatar
Re: What did my oil drain plug catch? (pic)
check out the comp R thread at the top of the lt1/lt4 forum.
Old Oct 2, 2005 | 09:31 PM
Birdman7389's Avatar
Yep, looks like more COMP R carnage
Old Oct 2, 2005 | 09:41 PM
Thanks for the heads-up on the sticky (as you can tell, I haven't kept up with the forum in awhile).
Wow, I'm glad I just finished putting my manifold back on yesterday. I'm going to have soo much fun taking it off and cleaning all the rtv again. Even better is now I get to take the rockers off and adjust them.
Old Oct 2, 2005 | 09:43 PM
camaroKid223's Avatar
ill agree, looks like you lost a retaining clip out of a newer style comp R lifter
Old Oct 2, 2005 | 09:53 PM
How about some info like how long have your Comp R's been in there and what preload have you been using? Also what high revs does the engine see and how often? Might as well throw in what cam, rockers and springs?
Old Oct 2, 2005 | 10:09 PM
Sure, everything was installed professionally May of '04 and the cam was a custom grind from SStrokerace (BRE-M1). The springs I believe are comp 918s (yes LS1 springs). Lifters of course are Comp Rs and preload was set to 0. The car truthfully has only seen a handful of ~6500 revs and was only driven for about 4500 miles before I started to notice a drop in power.
Old Oct 2, 2005 | 10:12 PM
Jazsun's Avatar
That sucks dude, I know how it feels when I did my valve seals I ended up re doing it now once, not twice, but 3 times. First time I didnt put the seals on right, second time I didnt use LT4 retainers/locks and was nervous, so the last time I put them on w/ the new rockers. Sucked, but in the end it will be worth it.
Old Oct 2, 2005 | 10:17 PM
Given that these retainers seem to be a little weak, I would think that no preload would aggravate the problem with them breaking. The internal plunger would always be exerting pressure on the retainer and pressure might actually increase at higher rpms due to a little lifter pump up.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
Queens94z28
Dec 20, 2014 09:11 PM
