What did I screw up?
Old Aug 19, 2005 | 11:06 PM
jchevy's Avatar
I was adjusting my rockers with the motor idling and when i loosened the intake valve on the #1 cylinder the rocker jumped off and the got caught up in the rocker next to it. Ended up bending the push rod on the exhaust valve
I heard some pretty serious thumps before i could shut it off. Did the piston hit the valve. I dont have a pushrod so i cant get it running till i find one.
Old Aug 19, 2005 | 11:51 PM
Z95m6's Avatar
Re: What did I F' up?
I think you'll be fine. I've had the same thing happen several times when adjusting rockers. Its some what hard to prevent that from happening the first time you start up a motor after having the drive train apart when you are working by yourself. A rocker can back off real quickly when you aren't watching them. I'd say the worst thing that probably happened was lifter damage.
Old Aug 20, 2005 | 01:00 AM
Green95Z28's Avatar
definately wanna checkout the lifter make sure its OK, sticka new pushrod in and see if it is holding oil and stuff, I destroyed a lifter when the rocker stud broke and did kinda the same thing
Old Aug 20, 2005 | 09:45 AM
jchevy's Avatar
Re: What did I screw up?
Thanks for the replys. How can I check the lifter to make sure nothing is damaged. Do i need to pull it out? Or can i just put pressure on it?
Old Aug 20, 2005 | 11:54 AM
Z95m6's Avatar
You can just stick a magnet in the hole and see if a bunch of lifter guts come up on the magnet when you pull it out.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Henson071
Aug 4, 2015 09:32 AM
Z28Freak86
Apr 28, 2015 10:35 PM
squarehead
Nov 21, 2014 08:02 PM
