What did I break?
Old May 4, 2007 | 06:36 PM
LenT1's Avatar
What did I break?
OK, like a retard I was doing a burnout on my stock 10 bolt. I was doing it for like 20 seconds or so and no one bothered to yell at me that only 1 tire was spinning. At the end smoke started pooring from UNDER the car coming from I think the rear main area. When starting the car I get a loud screech for like half a second and I cannot put it in to gear. The engine is fine but what did I break tranny / cutch related? Any guesses? Could it be some kind of line or did I probably physically break something bad?
Please help My car is trapped at work!
Old May 4, 2007 | 07:55 PM
seawolf06's Avatar
Are you sure one wheel was spinning? Sounds like you were only spinning the clutch. In which case you'll need a whole new clutch kit and at least resurface the flywheel. If you go with an aggressive clutch, get a billet flywheel.
If one wheel was indeed spinning without the other, then you need a new posi too.
Been there, done that...
Old May 4, 2007 | 08:13 PM
LenT1's Avatar
Im sure the posi is going out too. Thing is both tires were spinning at first then one stopped. The car was smoking from below for a good 5 minutes. Do you think its just the clutch assembly and flywheel?
Old May 4, 2007 | 08:34 PM
seawolf06's Avatar
Sounds like posi and clutch assembly went together.
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Aug 17, 2015 09:50 AM
Cam's maro
Aug 11, 2015 07:45 AM
