What cylinder TDC when dot to dot on timing chain?
Old Jan 14, 2004 | 07:51 AM
DR.ZED's Avatar
I've removed all my valve train components to install a new top end.
When I line up dot to dot on the timing chain, what compression stroke will I be on? The reason is so that I can bring it back to #1 to start pulling out springs, with the hub on.
12 o'clock the arrow points at TDC compression stroke of #1.?
Old Jan 14, 2004 | 07:55 AM
Dots together is #6 TDC compression stroke, but both #6 and #1 pistons are at the top of their travel (#1 being on the exhaust stroke). Clear as mud?
Old Jan 14, 2004 | 08:15 AM
DR.ZED's Avatar
Like... take more than 15 seconds to answer my posts next time okay????
It is clear. I had a SBC engine builder explain it to me.
Take the firing order and write them down. Like this:
1 2 3 4
5 6 7 8
So, #1 at TDC will be #5 at TDC if the firing order went 1-2-3-4-5-6-7-8.
Actually Rob, I neglected to keep the valve train on and find TDC before I took everything off. Ahh well.
I'll rotate 90 degrees plus whatever firing order I need to get to #1, and then do the wrapped screwdriver in the cylinder trick to get TDC.
Thanks!
Old Jan 14, 2004 | 08:57 AM
InjectedSS's Avatar
Actually it's
1 8 4 3
6 5 7 2
Old Jan 14, 2004 | 09:05 AM
DR.ZED's Avatar
Originally posted by InjectedSS
Actually it's
1 8 4 3
6 5 7 2
I KNOW!!!!!
LOL!
Old Jan 14, 2004 | 09:59 AM
FireAm94's Avatar
"if the firing order went"....not "the firing order of an LT1 is"..hehe
Joe
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
