What could this part be (under car) ???
Old Oct 24, 2005 | 04:15 PM
MTBeni's Avatar
Car is a 97TA A4. I was under the car yesterday checking out some possible leak and noticed a plastic component with a electric connector and what appears to be 2 vacuum ports. It is located on the driver's side near the exhaust manifold. It was not connected at all, just bolted there. The wiring harness that fits it is hanging (unconnectd and plugged off) next to it. What is this and should it be connected? The car is completely stock (all EGR still there) except CAI and catback.
Old Oct 24, 2005 | 04:22 PM
BlownF1's Avatar
Re: What could this part be (under car) ???
Can't think of it off the top of my head, but a picture would get you a quick answer I bet.
lt11997's Avatar
Can you get a pic, It's near impossible to tell you exactly what it is without looking at(for me anyways). Maybe shoebox or somebody else can tell you.
Old Oct 24, 2005 | 04:23 PM
lt11997's Avatar
Is it on the back of the intake?
Old Oct 24, 2005 | 04:29 PM
wrd1972's Avatar
Could it have somthing to do with the ASR traction control?
Old Oct 24, 2005 | 04:36 PM
flatlander757's Avatar
I think you're looking at the sphincter bypass valve
Old Oct 24, 2005 | 04:38 PM
MTBeni's Avatar
I have no way of hosting a pic. It looked like it was bolted to the back/side of the intake. Thanks for the help though. Keep the ideas coming
Old Oct 24, 2005 | 04:43 PM
Honda Hunter's Avatar
lol
Old Oct 24, 2005 | 04:46 PM
Maybe the EGR valve...
http://shbox.com/1/egr1.jpg
Old Oct 24, 2005 | 04:47 PM
sssalah's Avatar
That should be the EGR soleniod valve.
Old Oct 24, 2005 | 08:45 PM
MTBeni's Avatar
Thanks for the pic but it doesnt look like that. I could only see it from under the car, between the driver header and the engine block. It is about the size of a fist, but not round. Thanks for the inputs.
Old Oct 24, 2005 | 08:52 PM
1993Fast_Z's Avatar
is it a black round piece about the size of an altenator, is it in front of the manifold? this could be your smog pump....
Old Oct 24, 2005 | 08:58 PM
Turbo6's Avatar
Smog pump? Is it on the front of the engine, near the accessory belt?
Old Oct 24, 2005 | 09:05 PM
1993Fast_Z's Avatar
well, i dont think that mine (1993) is belt driven, it is electric driven, but yea it is black and looks somewhat like an altenator with two hoses coming out the back of it, also called the A.I.R pump, look it up on yahoo, or something...a see a pic, it sits on the drivers side, right at the front under the CAI
Old Oct 25, 2005 | 07:43 AM
wrd1972's Avatar
Sounds like the oil pressure sender unit
