What could be causing this?
Old Jun 13, 2004 | 05:16 PM
Cerwin Vega Fan's Avatar
Question What could be causing this?
When I purchased my car you could tell it had a rough life by the suspension. I was kind of worried about the engine being ragged out but that doesn't seems to be a concern no more. The engine runs fine, it is not burning or leaking oil at all. But something I have noticed, when the car is pushed to WOT sometimes smoke will pour out of the exhaust. I'm not sure what it is since both times this has happen at night. I'm guessing the smoke is un burnt fuel since the injectors are suppose to be over sized. Do I sound right on my assumption or could it be something else?
Old Jun 15, 2004 | 12:48 AM
I wish I could tell what color the smoke was. But their was a truck behind me and with the headlights on, the smoked regardless of what color it really was looked white. One thing I did notice was when I pushed the car to WOT (from around 20mph), the car seemed to hesitate for a second. Like it was over loaded or loading up with fuel, then the car took off and the smoke started pouring out the pipes.
Old Jun 15, 2004 | 12:50 AM
HBHRacing's Avatar
finding out what color smoke it is would be a good start.. black, blue, white etc etc
Old Jun 15, 2004 | 06:12 AM
madwolf's Avatar
Do you know if it was programmed for the larger injectors? Are you sure they're larger? If you can take a picture of them, I can tell you what they are... or at least if you can tell me their color/numbers on them.
My guess is that your car is running rich and that is black smoke (unburnt fuel) coming out of your tailpipes.
Novo
Jun 14, 2016 02:58 AM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
