what is the correct way to use sea foam deep creep for tb
Old Feb 4, 2003 | 08:02 PM
red96z's Avatar
are you supposed to run car and spray into tb with blades open and also should i wait to do this when i use an oil flush cause im going to flush when i repiace my cats with straight pipes i will also be replacing the front o2s with new ones cause im sure i will need to they will get dirty i hear thanks for the help randy
Old Feb 5, 2003 | 12:44 AM
red96z's Avatar
ttt
Old Feb 5, 2003 | 07:08 AM
shocktrp's Avatar
http://w3.one.net/~roz/cars/z28/seafoam.html
Basically, you put the liquid in the vacuum lines & stall the car after 1/2 can. Then you remove elbow & manually open TB blades & use the aerosol spray.
Aaront810
Aug 29, 2020 09:34 PM
PopoFormula
Oct 12, 2015 04:19 PM
drt
Sep 27, 2015 04:39 PM
Fatdog2
Sep 16, 2015 11:04 PM
95craz28
11
Sep 12, 2015 07:47 AM
