What coil to choose
Old May 7, 2005 | 03:42 PM
My94T/A's Avatar
What coil to choose
Hi, I been having a very annoying surge in my car. So Fastbird93 on this board been helping me out doing few scan and trying to find out what the problem is. Well today we spent few hours scanning the car and adjuesting the IAC. Then Fastbird93 noticed that there's was a bit of stumble when you give it some gas and winded up looking the coil. To begin with the coil was upside down, and it's the stock one. How I know it's stock the ribets are still there. We ran it through one of his coils and it seemed to run away better. So i decided to get a new coil and 160 stat Thermo. For for the coil what should i get Crane Cam, MSD or Hypertech. And for the thermo which one SLP or Hypertech. Thanks for all the help, sorry it's soo long.
Old May 7, 2005 | 03:44 PM
pHEnomIC's Avatar
Re: What coil to choose
for thermo, just go to autozone, and get a 160* one, it will be like 5 bucks, works the same, saves some money.
Old May 7, 2005 | 03:51 PM
My94T/A's Avatar
Also it is true that After market coils kills the lifespan of the Of the Opti?
Old May 7, 2005 | 03:54 PM
madwolf's Avatar
That thermostat WILL NOT work on an LT1! It's not designed for a reversed cooled engine. If you are doing a 160* stat, you need to get a Hypertech one or another which was designed specifically for the LT1.
As for the coil, I would go with a stock GM replacement, although I have used an MSD in the past and didn't have any problems with it.
Old May 7, 2005 | 03:57 PM
madwolf's Avatar
That is a rumour and it's about aftermarket ignitions, not coils, but who knows. I choose to go with GM replacement coils since they work fine and they are meant for your car.
Old May 7, 2005 | 04:35 PM
My94T/A's Avatar
Thanx for all the replies and responses, any other opinions.
Old May 7, 2005 | 05:40 PM
pHEnomIC's Avatar
Might as well get the gm coil, its only 25 new.
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
