what is causing this noise?
Every time i come to a stop, or go over a speed bump, i hear a creaking noise coming from the rear...it almost sounds like when you step on a woodem floor in a house...is it just the rear springs contracting and retracting? I have no idea wha it could be, or what could make it go away..any ideas?
more and likely its your trunk hatch. When you go over a bump next time turn around and look at where the trunk latches in the middle. I bet that it moves up and down quite a bit. Thats what mine does. I got the same noise. I got some SFC's and it got rid of a lot of the noises my car was making. So if you don't have those yet i would recommend you get some. They are a great mod.
I have a weird noise too but it's whenever I turn the steering wheel seems to be getting more frequent and I'm getting worried. I hope it's the rack and pinion cause I got a lifetime warrenty on it. It sounds like a thumb or slight quick knock sometimes it will do several small ones. Any ideas?
Once i got my subframe connectors I got rid of most of the noises in my car. I get the same squeeking your describing too and it is coming from the rear hatch area. Its not the springs but, after i tightened up everything in the back, the noise is almost nonexistent now. Now the only noise i have left is my damn exhaust, I knew putting that off-raod pipe on would open up some new nopises Ha Ha Ha
colts0455
13
Aug 7, 2015 09:15 PM
Aug 5, 2015 08:35 AM
