What can I use to plug the manifolds after AIR removal?
http://shbox.com/1/diverters.jpg
The manifolds have diverter valves on them I need to block. What do I buy to do that?
Re: What can I use to plug the manifolds after AIR removal?
I plugged my manifolds with two bolts. It's been so long and now I have LT's I don't remember the exact size bolt. I do know it should be either a M18,M20,or M22 and I picked up the bolts at a local auto parts store.
I went to a dodge dealership and you can get oil drain plugs for a 94-00 Cummings Disel. Not exaclty sure on the year range but if you ask for something like a 97 Ram they will def fit. Was a perfect fit on mine except the don' screw in %100 mabey about %75 but they work great, no exhaust leak or anything.
:d :d
:d :d
Originally Posted by fubar569
:d :d
:d :d
i had the edelbrock T.E.S. headers...with AIR injection...and they came with an adapter to adapt to the stock header input...i just took out the AIR and removed the adapter...installed 5 pennies in each hole and reinstalled adapter. NO LEAKS!! WOO!!
lol
lol
i went and got a m22 for mine and it didnt fit. all i did was go to a hardware store and i took the fitting with me that came out of the manifold. they found me two plugs within a few mintues and i think they both cost me like 2.34. very cheap and have no exhaust leaks whatsoever.
what did you guys use to take the fittings off without having the manifold off on the passenger side? I have a buddy that is wanting to do this and he can't figure out how to get to the passenger side without removing the manifold itself. Basically what tool/tools did you use to get to it?
