what can i use to block off the egr ?
Old Feb 22, 2004 | 11:08 AM
SLeeper94Z's Avatar
is ther anything that i can use to block off the egr fitting on my long tubes ?
Old Feb 22, 2004 | 12:13 PM
2cub49's Avatar
Well the AIR Fittings at the front are 3/4 fine thread so you could use some short bolts or some plugs.
The EGR you could block with a small piece of flat plate with a hole drilled in it for the bolt.
TPiS makes a billet piece but it's 12.00 plus shipping
Old Feb 22, 2004 | 12:26 PM
LPE Z convt's Avatar
Your local GM dealership sells them for less than $10.. Just tell them you need a EGR block off plate for a 96 LT4 corvette ....
Old Feb 22, 2004 | 02:57 PM
SLeeper94Z's Avatar
this is what i need for the egr flange on the header
Old Feb 22, 2004 | 03:47 PM
Josh-'04 GTO's Avatar
Got mine from Steve at SJM Manufacturing:
http://www.mycamaroz28.homestead.com/
Good guy to deal with!
Old Feb 22, 2004 | 03:49 PM
SLeeper94Z's Avatar
has anyone sealed there egr on there header with it on your car? i can barley even touch it. any tips thanks
Old Feb 22, 2004 | 03:53 PM
I did, using the plates that I mentioned the post above yours. It was actually pretty easy.
ibanez6rg's Avatar
I did, it just takes patience and small hands.
SJM Manufacturing is awesome, very fast shipping!
Old Feb 22, 2004 | 04:10 PM
SLeeper94Z's Avatar
i lost my bolt that goes to the headers, what kind bolt did u use to mount the egr block off plate
Old Feb 22, 2004 | 04:57 PM
Janny's Avatar
I stuck a dime in the orifice. Works great. It's cheap. Nobody can can see that it is ghetto. Ooops, now everybody knows.
Old Feb 22, 2004 | 05:50 PM
SLeeper94Z's Avatar
dime
did u jb weld this dime in there or anything ? or did u just put it in there?
Old Feb 22, 2004 | 05:59 PM
Re: Your local GM dealership sells them for less than $10.. Just tell them you need a EGR
No that is not what you need i misread your post i thought you were talking about the manifold where the egr mounts...... But if you are blocking the one off on the header why not pull the egr and block it off along with the one that runs from the header to the back of the intake also
Old Feb 22, 2004 | 06:04 PM
SLeeper94Z's Avatar
I would but i dont have the plates yet , i jus never in stalled it on my header it was jus hanging there , wouldnt the header leak with that egr flange open?
Old Feb 22, 2004 | 07:48 PM
Janny's Avatar
Re: dime
I gobbed it up a bit with a bit of high temp RTV to stop it moving around and stuck it in place.
RUENUF
Mar 13, 2016 03:37 PM
marlar98
Oct 21, 2015 02:02 PM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
