What can I reuse? LS1 brake parts list.
Old Sep 24, 2003 | 02:29 PM
zslates's Avatar
Which parts need to be replaced for a swap to LS1 Brakes. There are lots of parts on here that Im sure I can reuse. Am I right in thinking that I can reuse #'s 6, 7, 9, 10, 15,16. Also I dont know what 8 is?
THanks
Zack S.
1. 18060620 LS Knuckle
2. 18060621 RS Knuckle
3. 18042491 LS Caliper
4. 18042492 RS Caliper
5. 18060230 Rotor (x2)
6. 22163505 LS Brake Hose
7. 22163506 RS Brake Hose
8. ?? Caliper Mounting bracket with bolts (x2)
9. 7470587 Wheel hub (x2)
10. ?? Wheel sensor (x2)
11. Cottor pins
12. Brake Fluid
13. WD-40
14. Brake Pads (with metal clips)
15. 22145478 Upper Ball Joint (x2) (IF NEEDED - includes nut & pin)
16. 22156500 Lower Ball Joint (x2) (IF NEEDED - includes nut & pin)
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
