what can i do to get more hp
Old Oct 5, 2005 | 04:37 PM
  #16
Bersaglieri's Avatar
Re: what can i do to get more hp
The crank pulley is an underdrive pulley, its a 23% underdrive pulley that replaces the stock balancer/pulley in order to not just underdrive but also save on rotating weight. All others I have ever seen just bolt on top of your stocker, adding even more weight than you had stock. Like I said I wouldnt do it any other way.
Highly recommended and worth it.
-Dustin-
Old Oct 5, 2005 | 04:42 PM
  #17
mattybz28's Avatar
-Dustin-
Poop, i meant to say did you also do the alternator pulley
Old Oct 5, 2005 | 04:51 PM
  #18
Alvin@pcmforless.com's Avatar
Originally Posted by redington
i have a hypertech that the guy gave me but its not in the car nor will it be put in the car. I plan on doing a tune. About how much does a dyno tune cost? Aslo if i do a dyno tune should i do pcm4less tune also?
-Mike
If you have a hypertech chip you can send that in to us to have it reflashed to save anthor $25 bucks.
Our normal price includes a memory adapter so theres no need to send us your stock chip.. those adapters cost us plenty so if you have your own chip/adapter that can be reflashed we pass the savings right along to you.
Old Oct 5, 2005 | 06:20 PM
  #19
redington's Avatar
hey alvin i might just do that. But the reason i do not want to do head and cam is the $ too much for me right now. I want to do a 100 nx wet shot. I was told that i wouldnt need to upgrande anything really. MAybe a fuel pump. But i was also told that if mine works fine i shouldnt even have to worrie about that. I only want spray for some bigger races. I would say maybe spary it 5 times a month maybe less. Any info would be good.
-Mike
Old Oct 5, 2005 | 06:29 PM
  #20
No I did not use a ALT pulley. Just the 23% crank replacement. The battery volts are low 12's at long stop lights, but I just corrected this by upping the idle RPM's using a Madwolf tune. It wasnt causing any problems, even with my 1200 watt system bumpin, but I just feel better knowing its not dipping down low, who knows, it might kill my opti, and I am trying hard not to let that happen...again. Some use a ALT overdrive pulley to help with voltage levels but your actuall becoming counter productive at that point, why not just up the idle?
-Dustin-
Old Oct 5, 2005 | 07:26 PM
  #21
The stock fuel pump starts to loose steam around 360 rwhp in my experience. I would replace it if you plan on making more than that.
