what can i do to get more hp
Old 10-04-2005, 07:17 PM
redington's Avatar
Ok guys I am saving to get a NX wet kit but what else can i do to gain hp without doing heads and cam? Here are my mods now. 93 z 28 M6
SLP CAI, Trick Flow Elbow, 160* stat, Pacesetter Long Tubes, 3" ORY no cats, SLP Loudmouth, AIR!, EGR!, Strange 4.10's,
I mean do pulleys actually make hp? Also what about ignition? What can i do to make more hp?
-Mike
redington is offline
Old 10-04-2005, 07:26 PM
Jazsun's Avatar
Re: what can i do to get more hp
Try a tornado I dynoed mine at 25RWHP.
Jazsun is offline
Old 10-04-2005, 07:33 PM
redington's Avatar
are you serious? I have been told those things are junk?
-Mike
Old 10-04-2005, 08:54 PM
Jps 1LE's Avatar
Get some lower control arms and some relocation brackets. It will put a little more power to the wheels and help eliminate some wheel hop.
A good set of roller rockers can give you about 10-15hp with a stock cam, and more with a bigger one.
Pulleys can add about 10hp by reducing the amount of drag on engine accessories.
O yeah don't buy the tornado its a POS
Good Luck
Jp
Jps 1LE is offline
Old 10-04-2005, 08:57 PM
buzz12586's Avatar
Do you have some Drag Radials??? Those don't add HP but it will help you get it to the ground.
buzz12586 is offline
Old 10-04-2005, 09:08 PM
Bersaglieri's Avatar
- Electric Water Pump - Dyno proven 10 rwhp/rwtq
- ASP 23% Crank Replacement Pulley - In my opinion the only underdrive pulley worth buying. Most people report .1-.2 in the 1/4. It replaces the whole balancer unlike crappy piggyback pulley's.
- 1.6 Ratio roller rockers - I like Pro Mags but GMPP types work fine for medium to stock cams. I've seen anywhere from 8-14rwhp from these. You'll need the right studs/springs, etc.
- 58mm Throttle Body - Normally I wouldnt recommend this to a bolt on guy, but since your spraying you'd probably see a gain from getting more air in for the N2O HP.
- Ignition - might be good to help with adjusting timing, etc for the N2O, but not the first thing on my list.
-Dustin-
Bersaglieri is offline
Old 10-04-2005, 09:10 PM
OldSStroker's Avatar
Hey, quit picking on the new guy!
What are your goals redington? 11.99 at 110 in the 1/4? That's doable and streetable. No, the Tornado alone won't get you the 110 mph.
You make more useful power by processing more air thru your engine. Save your $ for heads and cam. You are probably spending it on gas with 4.10s, huh?
When you have more power than you can put to the gound, consider chassis mods. The stock Camaro does a pretty fair job of getting the power down.
Hang around.
OldSStroker is offline
Old 10-05-2005, 07:56 AM
2000GTP's Avatar
-Mike
They are, I think he was being sarcastic. I noticed you have your AIR and EGR deleted, did you have a mail-order tune done? If not, that is a great mod to do and adds proven HP.
2000GTP is offline
Old 10-05-2005, 10:45 AM
redington's Avatar
Yes I am running drs. I have the bfg drs. As far as the air and egr. All that was done when I bought the car. Im looking for consistant 11s. really what i want to do it run mid high 7s in the 1/8th. (we only have a 1/8 mile track)
-Mike
Old 10-05-2005, 10:58 AM
Alvin@pcmforless.com's Avatar
No kidding a chip in a 93 is worth 14rwhp or so.. Great bang for the buck.
Alvin@pcmforless.com is offline
Old 10-05-2005, 11:06 AM
TobyZ28's Avatar
I think alvins a bit biased
Seriously though a chip would be a great idea for a few more if it hasn't been done yet...
TobyZ28 is offline
Old 10-05-2005, 03:50 PM
redington's Avatar
i have a hypertech that the guy gave me but its not in the car nor will it be put in the car. I plan on doing a tune. About how much does a dyno tune cost? Aslo if i do a dyno tune should i do pcm4less tune also?
-Mike
Old 10-05-2005, 03:55 PM
mattybz28's Avatar
-Mike
You can sell that hypertech on ebay for close to 200 usually. Use that to get a mail order tune. I got my tune from madz28.com
If you've got air and egr deleted you probably already have to have some computer work done so make sure you're not wasting your money and doing a tune twice.
mattybz28 is offline
Old 10-05-2005, 04:02 PM
Super Moderator
JakeRobb's Avatar
What size nitrous shot are you thinking of? You may want to work the engine internals if you're planning on a big shot.
Why don't you want to do heads/cam?
JakeRobb is offline
Old 10-05-2005, 04:20 PM
mattybz28's Avatar
Did you do just the crank pulley or did you also do the underdrive pulley? Know of anyone that has both and if they think it's worth it?
