what can cause this?
Old Mar 14, 2007 | 07:19 AM
gpss97's Avatar
ok i'm not very knowledgable when it comes to camaros, but my question is, is there a sensor or something that if going bad will make the car run rich? i have checked my pump, changed filter, changed plugs. plugs were solid black and with only 1k miles on them. and still the first start up and for about ten mins my car runs rough.
the it will idle then if i hit the gas too much it dies, then i have to push the pedal to get it to start then it runs like as if its flooded which i'm sure is from holding the gas pedal down. and then it cuts out when i'm driving till it warms up then its fine. could it be bad 02 sensors? the guy at oreillys told me to check my map sensor, does that have anything to do with my problem?
sorry i'm just getting frustrated with this trying to figure out what the problem is.
Old Mar 14, 2007 | 07:35 AM
The IAT can cause that, if it were reading too low. It's operation can be checked with a scanner. If it were not working at all, it would cause a trouble code, though.
Old Mar 14, 2007 | 07:57 AM
gpss97's Avatar
i don't have one of those...haven't since before i rebuilt my motor. well i have one but can't find the plug from the wire harness to plug in. and it my motor never acted like this before. but i'll look for that plug again.thanks
Old Mar 14, 2007 | 09:04 AM
You don't have one? Very strange. I'm not saying that's your problem. You were looking for suggestions and I gave you one.
Old Mar 14, 2007 | 09:40 AM
gpss97's Avatar
lol, yeah i have one..its plugged into my cold air..but i just can't find the plug,lol..looked for a while when i was plugging the harness back up and couldn't find it. gonna take it and get it scanned today during lunch to see what kinda codes it comes up with, but thanks for the suggestion, i'll check it out.
mike
