What breaks in the rear end once you got the pawer to break it?
Old Dec 7, 2003 | 12:58 PM
Xride's Avatar
I know that once I get the power, and the traction, that the stock rear (is it 10 bolt??) is going to go bye bye, but why? what is it that breaks? and is there ways to help it last, while still getting good launches?
Old Dec 7, 2003 | 01:09 PM
HBHRacing's Avatar
usualy its the ring gear or the diff it self that brakes. you can rebiuld it with a better diff, gears, a rear end cover like the TA and weld the axle tubes, get stronger axles ect ect ect. Some people have had a lot of succes with this but in time.. and enough power. the 10 bolt will not hold up to well
Old Dec 7, 2003 | 01:11 PM
1994TransAm's Avatar
well first its gonna be a worn out u joint,then the c clips, then the gears, then the diferential.......
or so i expericend but mine never broke... just kinda made noises
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
