what bolts to replace on longblock
Old Jul 4, 2012 | 10:06 PM
slick1hunting's Avatar
My longblock should arrive in a week or two and wondering what bolts if any would be good to replace. I already have new flywheel and clutch bolts coming. Also should I replace the motor mounts and what do you recomend. My build is in my sig everything else is stock wt 160,000 on them. Thanks for any advice.
Old Jul 6, 2012 | 10:54 PM
96capricemgr's Avatar
Re: what bolts to replace on longblock
Poly does not last longer it is harsh and can cold flow, squeaks and rattles.
The headbolt comments are a joke right? Some year LT1s are TTY bolts but any engine builder that would reuse even the stockers on a stroker build isn't a real engine builder.
The steam pipe isn't really known for plugging up and does not need to flow a lot anyway, mostly meant to purge air pockets that would otherwise stay high and not want to be pushed down through the block to escape.
Old Jul 7, 2012 | 08:07 PM
Thanks for the input. I have arp bolt upgrades in the longblock. Just didnt really know if its worth the expense on anything else. I personaly figured the most could be reused but considered like the motor mount bolts and perhaps the intake but figured would probably be ok on them and just go a couple pounds extra on the torque. Honestly I also prefer to error on the safe side too so had to ask. I hate squeeky mounts and suspension. My truck gets rediculous at times good thing its loud or would drive me nuts.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
grabbem88
Feb 17, 2015 07:49 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ddr698
Jan 9, 2015 10:05 AM
