What is the biggest Cam that passes emissions?
Old May 10, 2004 | 03:34 PM
HardcoreRM125's Avatar
I'm just wondering, but what is the biggest cam a non-stroked LT1 could have in it, and still pass the sniffer?
This is assuming that all the major bolt ons are done
LT's, CAI, and so on ... And a good tune as well.
Also, with mildly or moderately ported heads would that allow a bigger cam to be more effeciant ( Emmisions-able ) ?
I know the hot cam can, so id assume the CC305 does? What about the CC306 though, Id assume NOT ... ?
Old May 10, 2004 | 03:59 PM
1 Nasty Bird's Avatar
Oh and an MSD box will help noticably in helping emissions!!
Old May 10, 2004 | 04:02 PM
z28marine's Avatar
how so?
Old May 10, 2004 | 04:22 PM
Pasky's Avatar
From what ive heard the CC306 is very non emmisions freindly. Depending on your state, long tubes are an automatic fail, thats how it is here in IL. If they actaully bother to look for em is anyones guess though. One of my buddys worked at an emissions testing place and a trick they used on louder sounding "sports cars" was to ask Qs like what motor is it an LT1 or LS1 and is it OBD1 or OBD2 and stuff like that. If you knew the answers and seemed to know about cars they went through your car with a fine tooth comb. Act dumb and be like, its a " super high output 350" or something lol make em think your a wanna be car guy
LOL, wish that did work, if they knew your a dumbass they'd probably look to see what you got then.
Old May 10, 2004 | 04:45 PM
SS MPSTR's Avatar
CC305 on a 114* LSA is about as far as you'd want to push it IMO.
Old May 10, 2004 | 04:52 PM
Terran2k's Avatar
what bout a xe224/230 114lsa with ported heads, 1.6RR, Jethot LT w/ CATs, True duals and CAI. would that pass the sniffer?
Old May 10, 2004 | 09:09 PM
Long tubes are a go, i just need ot have a cat, egr and air, AND PASS a sniffer ... Im not doing a cam for a while, i was jsut wondering though cause an idiot at school said a hot cam would fail, and instead of argueing, i figured id try to see how much bigger you can go on a non stroked engine ...
Old May 10, 2004 | 09:12 PM
And jsut a guess about the MSD ... But here goes .. Better spark = better burning in each cylinder. The better the fuel is burned, the less raw fuel passes through the exhaust, and the less raw fuel , the better the emissions
Damn im good.
Old May 10, 2004 | 09:51 PM
truedualws6's Avatar
You should be glad you are not in CA. They do a visual
inspection, hook up to the OBD connector, and put the
car on a chassis dyno and run it with a sniffer.
On the cam I concur with SS MPSTR. Which is why I am
going with a Crane 227, which is even easier to pass.
Old May 10, 2004 | 10:25 PM
Bud M's Avatar
I've seen where the 305 passed in California.
Old May 11, 2004 | 10:54 AM
SS MPSTR's Avatar
Mine did on a stock tune.
Old May 11, 2004 | 10:57 AM
SS MPSTR's Avatar
Damn im good.
On a mildly modded car, it really makes no difference. Go into the testing with fresh oil, a good state of tune and all your emission equipment functioning, and you'll be fine.
Old May 11, 2004 | 06:32 PM
limige's Avatar
i think someone posted last year they passed a CA emissions with a 306 by putting the stock tune in for the test, then put his old program back in when he was home. i'm pretty sure it was the 306...
armedtrigger
Feb 24, 2015 08:30 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
pecaspickles27
Wheels and Tires
Jan 20, 2015 02:31 PM
Queens94z28
Nov 20, 2014 06:03 PM
RichJ
Sep 26, 2002 09:43 AM
