What are the best Spark Plugs For a LT1!!!
Old Apr 6, 2008 | 09:34 PM
BMD18's Avatar
Hi i am wanting to do a lil tune up i have changed the oil and oil filter and got a new gatorback belt!! But i was wondering what are the BEST spark Plugs for a LT1? Some one told me NGK where the best but very expensive!! Please let me know your opions!
BOW TO THE Z28
Old Apr 6, 2008 | 09:36 PM
MTBSully's Avatar
NGK tr55's, and they really arent that expensive
Old Apr 6, 2008 | 09:46 PM
Stl94LT1's Avatar
TR55's are ~$1.50/each
Old Apr 6, 2008 | 09:52 PM
mdacton's Avatar
Is the car stock? and what is it? If stock I would run the stock delco plug.
Old Apr 6, 2008 | 10:53 PM
Fatdog2's Avatar
NGK's.Will bring a smile to your face.
Old Apr 6, 2008 | 11:47 PM
marshall93z's Avatar
Wow! Where?
They are like ~$3 around here.
Old Apr 6, 2008 | 11:55 PM
Bersaglieri's Avatar
Just put in Autolite 106's today to replace some fouled TR55's. Like a buck each.
-Dustin-
Old Apr 7, 2008 | 12:17 AM
jay_rich's Avatar
Im running autolite 104 platinums gapped at .045 for N/A right now....the car had coppers in before and it ran solid.
I have some NGK BR7EF for the 150 shot i will be running.
Jay
Old Apr 7, 2008 | 12:32 AM
bombebomb's Avatar
I have ngk tr55's in mine, it has a spun bearing
Old Apr 7, 2008 | 06:13 AM
CheshireCat's Avatar
mdacton asked the question. What are you running? If it is a stock LT1, then there's no real reason to switch away from a stock style plug. The AC Delco's in mine were still strong past 115k miles. I replaced them with Autolite Platinums of the stock heat range. No problems.
If you plan on running Nitrous, then go with a copper plug. Otherwise, the stock plugs work great. It's a spark plug. Don't overthink it unless you've done a bunch of power adding mods that would require a different heat range.
Old Apr 7, 2008 | 06:36 AM
Unless when you pull your AC Delco's and half or more of the platinump pucks are gone. Maybe they have fixed that problem, but that's why I dont run them.
-Dustin-
Old Apr 7, 2008 | 06:42 AM
caldercay's Avatar
Originally Posted by marshall93z
Wow! Where?
There are different types of TR55's, hence the price difference. Go to
Summit and enter "tr55" in the search box - you'll see 5-6 types.
Old Apr 7, 2008 | 11:38 AM
$2.39 for the cheapest one. And it's the same one I used... "V-Power".
Old Apr 7, 2008 | 05:00 PM
az0884's Avatar
I used some cheap Autolite 106's and the car has never run this good.
I think more expensive is not always better, but then again i might be having to change them sooner than if I would have gone with a more expensive plug but It only take about 30 minutes to do on my car...maybe the headers make it easier but i laugh when shops say its like a 5 hour job.
Old Apr 7, 2008 | 05:11 PM
sam pace's Avatar
I love the NGK TR55IX. They are the Iridium plug.
They cost a little more, but they last 3 times longer and you can use nitrous with them.
They also have less resistance to spark.
I gapped mine down to .045". My car runs the best at that gap.
Lt1's suck to do plugs on, unless you are warped or have little fingers.
