What are the best LT1 heads?????
Old Jun 23, 2006 | 08:35 PM
Mike96z's Avatar
I was trying to figure out what are the best set of heads you can get for an LT1...... Which ones flow the best and put out the most power on a stroker application like my 388. This mean bigger valves too. I heard modified/ported polished/bigger valved LT4 Heads make the most power. Not sure if it's correct.
Thanks for input.
Old Jun 23, 2006 | 08:58 PM
MEAN LT1's Avatar
Re: What are the best LT1 heads?????
What are your power goals?. Everybody doesnt want/need 550rwhp.
Old Jun 23, 2006 | 11:04 PM
IdahoLT1's Avatar
Id talk to Lloyd Elliot. He knows his [edit]
Old Jun 23, 2006 | 11:13 PM
1racerdude's Avatar
TFS or a converted set of ProAction.
Old Jun 24, 2006 | 07:23 AM
SStrokerAce's Avatar
Gotta ask.... how much coin you wanna spend? Cause if there is no limit then, well there is no limit. BTW there is ALWAYS a limit to the coin, ALWAYS!
Bret
Old Jun 24, 2006 | 09:27 AM
96capricemgr's Avatar
and what do you want to call an "LT1 head" for absolute money is no object build I think few would argue with a converted set of SB2.2s. For a more realistic build lookin g to go beyond what stock castings can deliver(a lot more than most would believe) then the Trickflows already mentioned are great if you get them worked. That is what the fastest LT1 Impala wears, full weight consistent 9s at Vegas altitued, blown too.
Old Jun 24, 2006 | 09:36 AM
97WS6SCharged's Avatar
Converted Brodix 18 degree heads
Converted SB2.2 heads
Converted Arao 32V heads... oh wait, those are a myth
How is UB doing these days Bret?
Old Jun 24, 2006 | 10:18 AM
engineermike's Avatar
AFR 210/220/227 are the best flowing out-the-box bolt-on head. The 210 is pretty close to a true bolt-on, while the 220 and 227 require some special valvetrain components. My 210 Race Readies flowed 280/218 cfm peak. I'm a little disenchanted, though, in the slow-burn chambers, especially in a turbo application. They require 36+ deg timing to get max power.
Mike
Old Jun 24, 2006 | 10:21 AM
They still hangin out.... boy they are gonna be some work.
Bret
Old Jun 24, 2006 | 10:46 AM
Daniel6718's Avatar
32 valve...
or sb 2.2
Old Jun 24, 2006 | 01:37 PM
Mike96z's Avatar
So if my stock heads are ported and polished and flow 250+ then they would be fine with stock valves to make atleast 500hp+??? That's all im really needing because this is what I have but wanted to know what exactly are the best heads.
Old Jun 24, 2006 | 04:17 PM
1racerdude's Avatar
Those flow numbers will BARELY get ya to 500FWHP and everything else Better be spot on.
It would be easier to do it with bigger flow numbers 280-300CFM.
Old Jun 24, 2006 | 04:18 PM
marshall93z's Avatar
ALOT easier!
Old Jun 24, 2006 | 05:48 PM
Mike96z's Avatar
So what heads?
Old Jun 24, 2006 | 05:50 PM
speed_demon24's Avatar
Originally Posted by Mike96z
So what heads?
They asked how much money you are willing to spend and you haven't responded yet so how are we supposed to know? The best heads would be the SB 2.2 heads, but you better have $$ coming out of your *** to use those.
