What are the best heads for LT-1???
Old Jan 19, 2004 | 09:04 AM
  #16
mongse_1's Avatar
I agree with Rich. If you're staying all motor, a set of LT4 195s from AFR would be more than adequate. 220s will require shaft-mount rockers, offset lifters, etc and 210s would be overkill unless you're running a big-*** solid lifter and can use the airflow.
If you're looking to be wild, drop the dime on a set of Brodix T1s or even nuttier, SB2.2s.
Don't forget the fork out the cash for a different intake, pistons, and headers though.
Old Jan 19, 2004 | 11:40 AM
  #17
nickz95camaro's Avatar
Well basically im dealing with a fuel injected car (95 Z-28) but I'm just looking for big power ( i suppose along with everyone else) I am probably gonna stroke it to a 383 or possibly a 396....with the possibility of supercharging it or turbocharging it afterwards.....so i'm not sure which heads would be the best for those 2 factors mentioned above! I'm not really concerned with the money issue that much...so anybody know a place in NY that does good engine and head work? How are the Vette Doctors in NY? Anyone know if they are good with working on heads???
By the way, im a newbie to this technical engine stuff... (as you can all probably tell)
Old Jan 19, 2004 | 11:42 AM
  #18
And by the way, its basically a street car but i also want to be able to pound it at the track. But definatly, i need something that would also dominate on the street.
Old Jan 19, 2004 | 02:08 PM
  #19
mongse_1's Avatar
AFRs would be a good choice w/ a forced induction motor. Their thicker decks are ideal.
Old Jan 19, 2004 | 04:48 PM
  #20
Thanks for the replies guys
I'm gonna probably check out the AFR's. I'll let you all know how it goes.
Old Jan 2, 2005 | 06:20 PM
  #21
LT4orbust's Avatar
Re: What are the best heads for LT-1???
how much hp are you running now ....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Sergio
Jan 27, 2016 04:27 PM
kksi
Feb 16, 2015 06:49 PM
sskevinm
Dec 18, 2014 11:16 AM
