What is the best 350-400 rwhp setup that is emissions legal? im in cali
Old Apr 20, 2006 | 06:59 PM
  #16
hulettsz28's Avatar
Re: What is the best 350-400 rwhp setup that is emissions legal? im in cali
To whoever asked above.
Yes it is the stock internals, on a 50,000+ LT1.
It is 8 pounds of intercooled boost, with the msd box retarding a safe amount of timing, a very conservative tune, so I am good for a while. SHOULD be...knock on wood. When it does blow, I will do what everyone else does, build a 355 or 383 with a D1 or bigger form of forced induction.
Old Apr 21, 2006 | 01:16 AM
  #17
ddj19852003's Avatar
Thanx for all the input fellas, im still reading and looking to decide on the combo I will really be happy with.
Old Apr 21, 2006 | 01:37 AM
  #18
tiznodd's Avatar
Where in CA are you? Do you know if you have a dyno smog? LA and SF bay are both using dyno smogs now which seem to be better for those of us using larger cams from what I've heard. A member in Hayward passed a dyno smog at a test only station with a XE 230/236 and said he had some wiggle room still.
Old Apr 21, 2006 | 02:01 AM
  #19
kick Z tail out's Avatar
Originally Posted by roughneck427
Well if your buddy all he had a a few bolt-ons didnt pass there evidently must have been something wrong 50 k or not with the car.And as far as word of mouth Bryan tunes these cars day in and day out dealing with people in smog states.If you dont get really high in the duration and keep the LSA in the 114 range he will have no problem passing smog with a fresh converter and o2 sensors.And yeah peoples cars are different, people that know what the hell they are doing and people who dont
Yeah, whatever. Like I said, good luck buddy. Come back with your "definitely gonna pass" confidence after you get your smog done. Until then it's just hoping.
Old Apr 21, 2006 | 10:15 AM
  #20
OBE1 95Z28's Avatar
I'm in CA and have the dyno smog; been tested/passed 4 times with my Vortech blower and 218/230/114 cam. My friend just tested here with a 383, Vortech, 224/236/114 cam and passed no problem.
Old Apr 21, 2006 | 10:50 AM
  #21
Im in Hercules california just about 15 mins from concord right across highway 4.
Old Apr 21, 2006 | 10:55 AM
  #22
Hey man whats going on I actually have the article of your car I really like it we have the same color cars, yours is teal right?
Old Apr 21, 2006 | 03:01 PM
  #23
OBE1 95Z28's Avatar
That's me the teal one; and the 383 I spoke of is the silver F1 that's in the same issue of Camaro Performers.
Old Apr 21, 2006 | 03:46 PM
  #24
Brians car was in there?
Old Apr 21, 2006 | 04:35 PM
  #25
JakeRobb's Avatar
Super Moderator
I think this might be the first time I've seen bench racing applied to emissions testing.
Old Apr 21, 2006 | 07:25 PM
  #26
OBE1 95Z28's Avatar
Yep, the F1 is Brian's.
Old Apr 21, 2006 | 08:15 PM
  #27
Vigilante's Avatar
I've had a friend with a 50,000 mile stock Z28, nothing but a few bolt ons fail smog. He had to run around freaking out until he found someone to 'massage' things for him so he could pass.
My car has 3 times as many miles and it passed smog w/out any problem at all. My previous Z28 bearly failed (it was close to passing) with really, really bad plug wires and no cat. A nearly stock LT1 car has to be running pretty bad to fail smog, even in CA.
Old Apr 21, 2006 | 08:44 PM
  #28
89TramsAmGTA's Avatar
I belong to a 3rd gen club here in Southern California and a number of our members are running cams ranging from the hot cam up to the 230XFI cam and are passing smog. They are running either modified TPI or the Accel Super Ram. Vincent with his 355 is at the 373RWHP and 414RWTQ mark with more to come. He has a custom 226 degree cam from Lunitai. These motors are based on the L-98.
Old Apr 22, 2006 | 03:32 AM
  #29
God i need to figure my setup out and get it , got kiiiiiiiiiilllllllllllleeeedddd by my friends RX-7 tonight . Knew I shouldnt have ran him. Again thanks for the input, and do you guys think the Hotcam kit is worth it or can I go more agressive on the cam side ?
Old Apr 22, 2006 | 10:33 AM
  #30
hulettsz28's Avatar
The hot cam kit is OK for the price. The springs arent very good. I was in the very same boat you are in a few months ago. Im sure you can search the forum and read my posts and what not. For what its worth: I too was going to go with the hot cam, but then realized if I was going to cam it then I might as well do heads. Then I found out about LE and decided if I was going to take that route that I would definately not do the hot cam, but instead get a custom h/c setup. I went with the blower instead and am completely satisfied. If you need it now, are worried about emissions, and have a weekend or two, just buy a used (or new if you have the money) s/c kit and some injectors. I found mine on here for 2 grand. I would do forced induction. Just my .02
