What belt w/ a/c and p/s pully deletion?
Old Jan 8, 2004 | 09:16 AM
TUFF LT1's Avatar
I'm in the middle of doing a cam and heads swap and was wondering if it was possible to bypass the Air conditioning and power steering pump just for trips to the track. Does anyone have the part number for the belt that I'd need? I'll be using a march underdrive pully and alternator pulley also by the way. Thanks.
Old Jan 8, 2004 | 09:45 AM
trax's Avatar
I'm not sure if that's even possible. There is no straight-shot path to the alternator from the crank pulley, so you can't really run a smaller belt straight between them.
If you plan on removing AC and power steering permanently, I would get a relocation kit like the one made by MORE performance. It relocates your alternator to where your AC compressor normally goes, and puts it on a REALLY short belt.
Old Jan 8, 2004 | 11:35 AM
TUFF LT1's Avatar
Ok thanks, I wasn't sure but that cleared it up.
magman
Apr 15, 2016 03:08 AM
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
WPHIG2
Aug 27, 2015 06:37 AM
john henry
Aug 14, 2015 08:33 AM
