What is an avarege cost for a stock rebuild?
Old May 26, 2004 | 01:50 PM
93transam1234's Avatar
I got 110k miles on the car now thinking about a stock rebuild next year before i do heads and cam 9or at the same time as the rebuild)
What is a genral cost for a rebuild including labor (i would be doing none of the myself)
Old May 26, 2004 | 02:23 PM
Somnambulist's Avatar
down here in Texas you could find it for a little over $1k
Old May 26, 2004 | 04:33 PM
toegead93's Avatar
I just paid $900 to have the tranny built stronger than stock.
ie. better clutch materials, stronger bands, etc.
Old May 26, 2004 | 05:31 PM
white97z/28's Avatar
Probably closer to 2-3K around here with labor.
Old May 26, 2004 | 05:35 PM
Fuels94TA's Avatar
OEM parts will be very good in price, but labor will kill you. I say the same thing as white97z/28.
Vinny
Old May 26, 2004 | 06:43 PM
i think he's wanting an engine rebuild...
Old May 26, 2004 | 06:45 PM
this is including labor and the use of hypereutectic pistons and stock length rods...new gaskets...rings...etc
last i checked my renound local shop had ~ a 2 week turn-around if you dropped the car off...
Old May 27, 2004 | 02:11 AM
mineralwater's Avatar
$1k? damn, I should've flown my car to texas.
I was quoted $2800 for a budget rebuild, but they told my my block was so damaged, that the quote somehow inflated up to $4800. After a lot of dispute and BAR mediation, we finally compromised on $3300. So its not bad - but it took the shop 4 months.
Make sure you do research on whatever shop you decide to take it to, and check with your local BBB/BAR to see if they have a valid license and any registered complaints.
Good luck!
Old May 27, 2004 | 04:27 AM
IllusionalTA's Avatar
Just payed 1700 w/ a 1 yr/12K mile warranty.. i pulled it.. So if you do the work you save a butt ton of money.. I needed a new crank, rod's , and of course the piston's are new as well. This is just stock crap.. I had a spare block as well. i cracked mine figure 2K or so w/ you doing the work and about 2500-3K w/ dropping it off and picking it up.. Not bad IMHO..
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
