what all should i do to tuneup . . .
i have a 1996 z28 with 130,000 miles it still has original rotor , caps and wires . what all should i replace . i was thinking the water pump , wires , rotor , cap , maybe opti , pvc , fuel filter . any help will be appreciated . thanks jay clayburn
Re: what all should i do to tuneup . . .
I wouldn't mess with the Opti unless something is wrong. Everything else you mentioned would be fine. If you are going to replace the water pump I would get an electric w/p. Is there anything wrong with the car or does it run fine?
I would wait on the Opti and waterpump. Wires, plugs, PVC valve, fuel filter, air cleaners, and cleaning the throttle body would probably be as far as I would go with the tuneup.
Replace the WP with a stock rebuilt, before it goes to leaking and ruins the opti.
DO NOT use seafoam or any other additive on it. Along with what ya mentioned to replace have the oil and filter changed at the same time.
Use seafoam - why not? Just don't add it to the oil. Of all the cars I've used it on - about half of them had very noticeable benefits while the others were average or a little above (in other words....no negative experiences - just stay away from the oil).
