What are all the cheap mods I can do?
Old Sep 24, 2004 | 03:49 PM
Kurt Crosbie's Avatar
Like weight reduction, MAF, and whatnot..
Is there like a list of all of them somewhere?
Old Sep 24, 2004 | 08:16 PM
slopokrodrigez's Avatar
Re: What are all the cheap mods I can do?
Don't remove the screen from the MAF. I attended a class put on by Standard automotive parts. They informed us that the screen straightens the airflow for more accurate measurement by the MAF. The turbulence created by removing it can throw off the accuracy and be more detrimental than anything else.
If you use a cotton filter, don't over oil it.
Old Sep 24, 2004 | 09:02 PM
Z-RATED94's Avatar
slopok,
What about porting or useing aftermarket maf ends? Any gain there?
TIA, Rick
Old Sep 24, 2004 | 09:10 PM
BiGGinZ's Avatar
It wont throw the reading off much at all. You should just get a tune for it. Gain, maybe if you are running some major numbers. Cheap mods...how cheap?
T.B. Bypass-free or almost free
T.B. Airfoil- Like $20-30 used in the for sale section
Crank Pulley and Belt- Like $50-60 used or $100 new
160* Therm. Stat and Tune- Like $30 for the stat and $100 for a mail order tune (matters what kind of car you have and year)
Used Cai-$120 or so
Short Shifter- Don't know I have an auto
There are a couple.
Old Sep 24, 2004 | 09:28 PM
rpm4lalo's Avatar
If you haven't already, you can disable C.A.G.S. for free.
Old Sep 25, 2004 | 02:12 AM
ttt
Old Sep 25, 2004 | 07:53 AM
ECIV_96_Z28's Avatar
What the heck is C. A. G. S. ???
Old Sep 25, 2004 | 08:44 AM
GR8WHTZ's Avatar
C.A.G.S.- computer aided gear selection. The factory added this to improve mileage. It locks out 2nd and 3rd gears at slow speeds, so you have to shift 1st to 4th... PITA!
Dave
Old Sep 25, 2004 | 09:39 AM
i have a 6-speed. Were you talking about the automatic?
Old Sep 25, 2004 | 10:34 AM
BiGGinZ's Avatar
CAGS is only on the 6-speed.
Old Sep 25, 2004 | 11:36 AM
OH, thats why. I thought my gears were scerwed. How do I remove this CAGS?
Old Sep 25, 2004 | 11:49 AM
ScrmngChckn95's Avatar
you can eliminate it here. You can also eliminate CAGS with a resistor to some wire under the transmission, but I found this way to be the easiest for me, just remove two wires to the comp. When you're done, no cags and no skip shift light either.
Old Sep 25, 2004 | 11:54 AM
KWIK WS6's Avatar
From: Southern California, where do YOU live mutha****a?
TB bypass.
Old Sep 25, 2004 | 01:03 PM
come on guys, more mods...
Old Sep 26, 2004 | 01:29 PM
Originally Posted by Z-RATED94
slopok,
TIA, Rick
Anytime the MAF size changes, the programming to understand it has to be changed. The experts say, don't mess with the MAF.
