What is this?
Old Aug 15, 2013 | 08:29 AM
Chet1185's Avatar
What is this?
Anyone know what this is under my dash on the drivers side?
Sent from my R800x using Tapatalk 2
Old Aug 15, 2013 | 08:30 AM
Chet1185's Avatar
Re: What is this?
Old Aug 16, 2013 | 05:13 PM
Kevin Blown 95 TA's Avatar
Re: What is this?
That looks like a 80's era Soviet Bloc KGB AP module. I wouldn't press that button if I were you.
Old Aug 17, 2013 | 12:24 AM
Chet1185's Avatar
Re: What is this?
Lol. They aren't buttons though
Old Aug 17, 2013 | 09:04 AM
Re: What is this?
Look for an ID on that black box that is wired to it. It's nothing factory. What factory wiring it is wired to should give a clue what it is.
Old Aug 17, 2013 | 09:41 AM
Chet1185's Avatar
Re: What is this?
Thanks. I'll go check it out
Old Aug 17, 2013 | 10:31 AM
Chet1185's Avatar
Re: What is this?
The little clear box says shock sensor. Do i'm going to say an alarm. There is a connector going into the box, see pic below. That's not a factory connector is it?
I want to cut and remove it. Any possibility that Is what causing my battery to die all the time after a day of sitting?
Old Aug 17, 2013 | 10:41 AM
Re: What is this?
The "keep this side up" connector is not factory, nor is the black box. Trace where it is getting power and disconnect it.
Old Aug 17, 2013 | 10:50 AM
Chet1185's Avatar
Re: What is this?
I cut it. The number on the black box is ezsde1437, which doing a search for that number came up viper alarm.
Old Aug 17, 2013 | 12:16 PM
BombSquad's Avatar
Re: What is this?
It is a viper alarm, I have the exact same one in my 95 Camaro, old but mine still works.
