What are 30# SVO injectors?
(I know my '97 has 24# injectors) SVO, is that a Ford product? If so what year/model/engine can they be found on? Iv'e read their plentiful and cheap so I guessing they come from mustangs?
I got mine from www.nu-tekmotorsports.com but you can also try www.sybersport.com. Both have great.
Completely diferent design but works great on our cars.
Thanks for the info/links. I checked them out and got limited results however, Jegs carries Accell injectors with a wide selection. Anybody like those? According to their application guide stock uses their 26lb inj so what would I need with my set-up (XE230/236, heads by Lloyd, headers, 4.11's)?
AFPR are handy but what injector would support my needs with a stock(setting) FPR?
Thanks for the comments
I have my fuel pressure set at 39psi at idle without vaccum. But I am still playing with that. I may raise it to 41 or perhaps 43 where it is suppose to be (where Bryan programmed it at), but I wanted to lean it out a little.
I suspect it may be runnning a tad lean at higher rpms.
Good Luck
Good Luck
autoxr166
Sep 25, 2015 04:21 PM
