Wet outside...car misses badly..opti?
Old May 22, 2003 | 11:04 PM
Whitewolf's Avatar
Have any of you had this problem..i had a high rpm miss..found 2 bad plug wires..put new wires in..seemed smoother..drove it about a mile or so got a vibration..like a low rpm stumble..it started raining..driving it home..wouldn't rev over 3500 rpm..like it wasn't firing at all..wires seem ok..new coil..opti has less than 1000 miles on it but doesn't mean that isn't it..think maybe I could start it when it is dry and spray a mist of water aroudn things and see what gives? or is this a bad idea..also the car backfires slightly and there is a ton of black smoke under hard acceleration..however when it dries out car runs ok..but is down on power..thanks all advise appreciated
Brad
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
